Every where I have read about powder coating strongly discourage the use of you regular oven. You do get spatter from the curing process. I should take a picture of theinside of my oven so you can see what a year plus of curing does.
Keep an eye out of Craigslist - I see ovens locally for free.
Craigslist is an excellent source for cheap or even free stoves. That's how I got mine, and near Nashville, TN there were 3 or 4 available for $50-$75 AND two that were free to pick up. Couple was happy I came to get it out of their garage. I think i'm going to grab another one and run two ovens. That way can do a decent lot of parts at the same time.
Before I pc a part, I'll typically blast it or scrub it clean, wipe it down then outgas at a bit higher than cure temperature for twice the cure temperature time - so if powder cure is 10 mins @ 400F, then I'll outgas for 20 mins @ 425F. Once it cools, I go over it with acetone and if the rag comes away dirty, re-outgas it then wipe it down again with acetone. I'll do this as many times as it takes for the rag to come away clean. Just before I hit it with the pc, I run a propane torch over the jub quickly to make sure there's no bits of lint or rag material left on the job.
I pre-heat the oven and put the part in for curing only once the oven's come up to temp - that way the part is only in tere for the cure time.
Personally, I only have one gun and use it for all my colours without any problems.
Don't use duct tape as that will turn to rat $hit and leave melted adhesive on your job. To mask parts up, either use hi-temp tape or even aluminium foil an ordinary masking tape. If you're worried about the tape burning during cure, wait until the powder starts to flow out then pull the part from the oven and unmask it then pop it back into the oven for full cure.
A few parts I've done for my 82...
for the alternator did you remove the front and rear bearing before you baked it? nice job
1) degrease the parts
2) sandblast them
3) blow them off with compressed air
4) use wax and grease remover until the rag wipes off clean
5) place the parts in the oven to burn off any other oils I have missed
6) let the parts cool
7) apply powder
8) place in oven to cure
Here are some Items I did...
Here is the blast cabinet I made - I cut the wood panels at school and assembled it at home...it works great.
how much did that cabinet cost to make? and that stuff came out damn good.
I think around $200. I built it as a school project, so I had to use expensive plywood to make it look good. I made the cabinet hopper out of 1/8'' steel because it was easier to cut and deal with than having to deal with all the angles with 3/4'' plywood. The metal cost a lot to build it too. It can be built for about $100 if you budget it out...I had to finish it before the semester was over, so I was pressed for time - that's why I used metal on the hopper...it was easier to work with. THe plywood wasn't cheap either...I think its altic birch. You can use the cheap stuff from home depot and it will work just fine...that's what I would have done if I didn't have to make it look good, but that wasn't the case.
Ive got the craftsman setup and I use it for little parts that may not always be seen but ones hat i might not necisarily want to paint or leave bare metal, so I use the industrial colors that Sears sells. It works for me. But I see some powders out there that are base coat/top coat. Is it that simple pc one color, cure then top coat and cure again? After seeing some examples I would like to redo some parts.
The Sears gun is capable of doing a great job - try some fancy colours from Eastwood etc, I think you'll be pleasantly surprised.
Columbia Coatings has lots of colors and prices are good they even have specials that you can get. Real quick on shipping and great to call if you got some questions.
Good Luck wro87
OK, now that I have some good sources for powder, how about giving me some good ideas as far as hanging the parts in the oven. Did you buy a premade rack and hand it from the roof of the oven or did you create you own system. Please post some pics if you have any.
I'm assuming the hangers leave a bare spot in the finish. Is there any way around it or do you just run it through a spot you don't want coating anyways, such as a bolt hole?
I made a "paint booth" out of a large computer box and hung a piece of slotted angle across the top. I use a small hanger thru a hole in the item I am coating and hang it in a hole inthe angle. Once I coat the part, I hang it in the oven using the oven rack that came with the oven.
The biggest PITA so far has been the lower control arms. They fit but it's not easy.
