Horn Not Working
First insert Spring #2 then the Eyelet #3 (the upset end first) into the plastic horn tower that is part of Contact Asm Lower #1. You should press Insulator #4 into the end of the horn tower to hold the spring and eyelet in place. The eyelet should easily slide up and down in the horn tower.
The horn tower should extend up through the Hub Asm 3949110. The Contact Asm Upper #7 will have a leg that extends under the contact. The eyelet should press against the leg and always be in contact with it. The horn cap assembly (9, 10, 11) should snap into the Contact Asm Upper. Now when you depress the horn cap, the upper horn contact should close completing a ground path back down through the steering column.
Jim
Jim
