75 headlight binding
Old Feb 11, 2008 | 06:06 PM
gotn20guy's Avatar
gotn20guy
Cruising
Default 75 headlight binding
the drivers side headlight on my '75 binds when raised, a quick tap on the body behind it, and it pops right up. I've tried the adjustment screw in the center of the assembly, all that did was raise the front of the door, it's the back that is binding. any help on this would be greatly appreciated, as this has already damaged the paint behind the headlight
Old Feb 11, 2008 | 09:02 PM
croaker's Avatar
croaker
On each side there are some bushings loosen these it's kind of a tight area now equal out the spaces on each side this should get you close. Go to the ecklers site and serach the bushings then you'll know what your looking for. Mine caught the clear coat of my new paint could of done some real damage but I was lucky
Old Feb 11, 2008 | 09:43 PM
seventysixvette's Avatar
seventysixvette
Just for the heck of it, check your header bar also.
One of the headlight doors was binding and rubbing slightly on my '76. When I checked it out, the header bar was so swollen with rust it had put the corner of the door in a bind.
I had to remove both headlight assemblys when I replaced the bar, so it was a good time for a complete rebuild of the assemblies too.
John
Last edited by seventysixvette; Feb 12, 2008 at 04:07 PM. Reason: Still can't spell
Old Feb 11, 2008 | 10:07 PM
gotn20guy's Avatar
gotn20guy
Cruising
awesome, thanks for the help, I'll check both of those as soon as the sun comes up!
Old Feb 12, 2008 | 12:48 AM
croaker's Avatar
croaker
Fill in your profile us 75 owners gotta keep up with each other
To 75 headlight binding
