Another weird 68 question
Old Feb 15, 2008 | 10:17 AM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Default Another weird 68 question
The aim shows my vacuum overides in the middle under the column. Mine are on the right side of the dash over the gas pedal. It looks correct, because there is a special rubber block they mount in. Is this another 68 early design. Will this madness ever end.
Old Feb 15, 2008 | 11:18 AM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
They line up with the steering column on my 71...sounds like another 68 difference.
Old Feb 15, 2008 | 12:39 PM
avalonjohn's Avatar
avalonjohn
CF Community Team
Veteran: Marine Corps
St. Jude Donor '25
Budman, early 68's were over to the side, later 68's and up were in the middle. What is the build date of your car?
Old Feb 15, 2008 | 12:44 PM
DZRick's Avatar
DZRick
Bud, what's the build date on your car? Can you post a picture of your override switches, I'd like to see what that rubber block looks like.
I thought the aim listed any changes during production?
Here's my June built 68.
Old Feb 15, 2008 | 12:45 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Nov. 28th. Looks like I have 99% of the early stuff. When I changed all the hoses out I noticed the tape around the t-fittings and thought it was bubba'ed. Now I'm learning that is what the factory did to seal the lines.
Old Feb 15, 2008 | 12:50 PM
DZRick's Avatar
DZRick
I must have been waiting for photobucket to upload my picture while you were posting.
I thought I had a pretty good handle on the differences in the 68s but it seems that they are endless.
Old Feb 15, 2008 | 01:25 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
I'll take some tonight.
Old Feb 15, 2008 | 01:36 PM
Vetdremz's Avatar
Vetdremz
I also feel your pain!
(another '69 owner)
Old Feb 15, 2008 | 09:08 PM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
...the early '68s were indeed that way, then complaints started getting back to GM about taller/longer legged people hitting their knees on them, so it was just another one of those '68 only changes.
Old Feb 15, 2008 | 11:19 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
As requested
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old Feb 15, 2008 | 11:22 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
This was the other early 68 thing I found. Flasher is behind the ashtray, not the passenger side dash.
[IMG][/IMG]
Old Feb 16, 2008 | 09:29 AM
Capella's Avatar
Capella
Nov of 67?
My April of 68 built car has them under the column and the flasher behind the pass side dash.
Old Feb 16, 2008 | 09:32 AM
Budman68's Avatar
Budman68
St. Jude Donor '07
That correct 67.
Originally Posted by Capella
Nov of 67?
To Another weird 68 question
