Birdcage???
Old Feb 15, 2008 | 11:07 AM
ens1967's Avatar
ens1967
Default Birdcage???
What is the birdcage on a vette? Sorry to ask such a question but I keep hearing people talk about checking the frame and birdcage.
Old Feb 15, 2008 | 11:30 AM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
Here you go,
Old Feb 15, 2008 | 11:37 AM
ens1967's Avatar
ens1967
Thanks!
Old Feb 15, 2008 | 11:59 AM
ohsofast's Avatar
ohsofast
When inspecting the bird-cage what exactly are we looking for? Rust, i would imagine but what else?? Are there any problematic points with in the bird-cage?
Old Feb 15, 2008 | 01:58 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
Rust is the usual problem and is most likely to occur in the lower corners of the windshield frame and the verticle pieces below them, although it can occur anywhere. If by "problematic points" you mean are there any inherently weak points, I've never heard of any.
Old Feb 15, 2008 | 02:08 PM
82Vettrin's Avatar
82Vettrin
Originally Posted by Glass Act
Here you go,
pic ought-to be made a sticky, as this is a very-often discussed term, and the average-layman (myself included) had never heard the term before joining here.
thanks Glass Act
Old Feb 15, 2008 | 02:24 PM
Glass Act's Avatar
Glass Act
Here's the area's that are noted for rusting on the birdcage.
As mentioned, the lower windshield area, and remove the kick panel to look for rusted out support frame as noted in this diagram.
Old Feb 15, 2008 | 02:30 PM
Glass Act's Avatar
Glass Act
Here's a couple of other diagrams.
Old Feb 15, 2008 | 03:05 PM
Paul L's Avatar
Paul L
Tip-toe softly past this one.
Old Feb 15, 2008 | 03:26 PM
swtato's Avatar
swtato
St. Jude Donor '05
thanks Glass Act
I was just about to suggest a sticky as well.
Old Feb 15, 2008 | 06:51 PM
jrzvette's Avatar
jrzvette
"Rust is the usual problem and is most likely to occur in the lower corners of the windshield frame and the verticle pieces below them..."
So much for that idea.
Old Feb 15, 2008 | 07:03 PM
Derby98's Avatar
Derby98
St. Jude Donor '09
Can one buy the complete Birdcage assembly?
How hard is it to replace?
Old Feb 15, 2008 | 07:07 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
not as yet that I know of. As for how hard on a scale of 1-10 1 being the easiset I would rate it a about 15. I never done it and I would never would want too. also the first pic is a bird cage from a 63-67 coupe
Old Feb 15, 2008 | 07:18 PM
A C's Avatar
A C
Cruise-In II Veteran
Holy cow!
That is the worst windshield frame rot I have ever seen....and I live in Minnesota, road salt capital of the USA. There has to be more to that story than the ordinary rust issues.
Derby...you can buy certain patch sections of the windshield frame from Zip, but as far as I know no one sells a complete birdcage. Unless the car is an L-88 or something, it really wouldn't be worth the labor to assemble a car around a new cage anyway. It's basically like hand building a new (old) Vette body tub.
Old Feb 15, 2008 | 07:35 PM
Derby98's Avatar
Derby98
St. Jude Donor '09
Thanks.
My kick panels are rusted,
I'll check with a local body shop & see if they can tackle the job.
Old Feb 15, 2008 | 09:44 PM
Zoomin's Avatar
Zoomin
2018 C2 of Year Finalist
St. Jude Donor '12-'13-'14-'15, '19
Are they as rusted as the windshield frame shown above? You miight try cleaning them up first to make sure it's not completely rotted out.
Old Feb 15, 2008 | 10:05 PM
MakoShark77's Avatar
MakoShark77
St. Jude Donor '24-'26
When inspecting a car, where exactly are we looking? From inside remove the kickpanels and look for rust. Around the windshield frame is easy enough...anywhere else? From underneath? Underhood along the firewall? The drawings are great I just gotta apply them to the assembled product.
I second the motion to "sticky" this thread
To Birdcage???
Old Feb 15, 2008 | 10:37 PM
jrzvette's Avatar
jrzvette
The windshield frame isn't always easy. If the rust is bad (but not extreme like the pic above) a lot of it can be hidden by the stainless molding. Another trick is to put sheets of white paper in the foot wells, lower the windows, shut the doors hard and examine the paper for bits of rust.
Old Feb 16, 2008 | 10:25 AM
77Vette4S&J's Avatar
77Vette4S&J
I had no idea what one was until I got my Vette and it took me a while to figure it out as well. That isn't a bad idea about making it a sticky.
Old Feb 16, 2008 | 10:41 AM
avner's Avatar
avner
ens1967: Look at this thread.
http://forums.corvetteforum.com/show...ighlight=avner
If you want you can fix everything.
Avner
