replace side veiw mirrors
Old Feb 17, 2008 | 01:22 PM
locust115's Avatar
locust115
Default replace side veiw mirrors
Want to replace the side view mirrors on my "79" vette. I have the door panel off but can not lower the window enough to get to one nut. Can some one help me out with this problem, is there a stop to remove? Sure could use some help on this.
Art
Old Feb 17, 2008 | 02:11 PM
Toms82's Avatar
Toms82
Hi,
Remove the top bolts holding the front window track. You will then have enough room to access the mirror fasteners.
Good luck,
Tom
Old Feb 22, 2008 | 11:39 AM
locust115's Avatar
locust115
Thanks Tom I will be trying this today. Thanks again
Old Feb 22, 2008 | 11:56 AM
wills670's Avatar
wills670
Unless they changed the way the door frames are I don't think you will gain access to the nuts. There is a piece of metal in the way. In the pic. if you visualize the door skin on this frame you will notice the bar that should be in the way. If you go to the tech section and look at the post about window regulators there is a whole lot better pic. it may give you a better idea of what you are dealing with.
[IMG][/IMG]
To replace side veiw mirrors
