The heater control screws on to a plate(heater control housing) that also has the vent control levers. Does this housing sit above or below the console? In other words,does the housing sit there and the console sits on top or does the housing go over the console and then the console plate sits on the housing?
Also, for the vent cables, they attach to the levers but where do the flanges screw in? I mean the flanges that are on the cable itself in order to hold the cable still so the lever moves it properly.
Hope you can understand the questions and if not I can take some pics of the area.
Any other tips on console re-install would be appreciated.
Wish I would have read this an hour ago: I JUST put mine back together! Small world. I believe the heater control unit sits on top of the console frame; then the metal shifter boot plate goes ontop of all of it with the four phillips screws in each corner. As far as the cable shield mount, let me go look. Meanwhile, here's my new radio install I just finished:
Okay - the heater control unit rests on top of the console frame (see pic). the cable is mounted to the console underneath the top of it. So if you're looking at your console from your seat, just below where the headlamp indicator lamp bar is - directly under it, the cables screw into the console with clips. I couldn't get a picture of it, sorry.
with the order of assembly.
The vent cables have the push on nuts that bite into the shaft so they don't slide off, If I undertsand your question. Look at the AIM or a vendor catalog that has a diagram of this area.
On my ’69 the vent cables were attached to the post coming down from the fiber optics cover plate. A push nut was holding them in place on the end of the post with a second nut flush with the bottom of the console to hold the plate in place. I’m not sure if your 70 is the same, but thought I would throw it out there.
I just did mine and its a pain in the ***. Bought a new center console and with the vinyl covering the airconditioning base plate was just a bit too wide to fit in (filed it down). There is alot of jimmying and adjustment needed to make it all fit and in the back of your mind is the gauge bezel can very easily snap in two.
