Muncie Gurus - A little help!
1. How the heck does the reverse shifter seal come out. I don't want to scar the shaft by getting too over zealous.
2. Also, there doesn't appear to be an input shaft seal. I can tell by all the goo in the bell housing that fluid was leaking there too. Is there suppose to be a seal there?
Thanks,
John
I"m not a munci guru by no means, but i have the same problem as you. i replaced the reverse same as the other two with a small screw driver pop it out. Don"t forget to replace the drive shaft yoke seal too.
Now on the oil inside the bell housing, if the tranny was over filled the oil will run out there (overflow) cause from what i read there"s no seal there. If it didn"t get there from overfilling then you have a worn case. fixable via replacing the case or having your case sleaved.
Mine doesen"t leak it pours!!!!!!!!! I"m interested in what you find out with yours, so please post back with some results.
ps: use some blue loctite on the linkage nuts when you put them back on. use brake cleaner to get all the oil off. david
