1968 owners only please
Old Feb 23, 2008 | 11:04 AM
AWilson's Avatar
AWilson
I only know enough to be dangerous but isn't the stamping on the differential and or the trans. in part tell you what the engine was? Assuming those are original.
Old Feb 23, 2008 | 12:24 PM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
Nope not at all, only possibilities, no type of concrete proof obtained from tranny or rear.
Old Feb 23, 2008 | 12:26 PM
427SIXPACK's Avatar
427SIXPACK
Originally Posted by Greg
Yes.
Yes, I really care what it was, because if it was originally a 435hp car I would locate a period correct intake, heads, carbs & block, deck it, broach it and restamp it so no one could tell it was counterfeit, then sell it at Barrett Jackson for a small fortune.
.......satisfied?
i thought so
you know i'm just kidding right ?
Old Feb 23, 2008 | 01:18 PM
AWilson's Avatar
AWilson
Per my NCRS judging manual the differential stamp will tell you if it is a SB or a BB.
Old Feb 23, 2008 | 01:52 PM
427SIXPACK's Avatar
427SIXPACK
THE ONLY THINGS STAMPED ON A DIFF & OR TRANNY ARE DATES & MODEL NUMBERS
FOR EXAMPLE...... M21 OR M20 OR 3:08 OR 4:11 ETC.
NOTHING MORE, SO HOW WOULD THAT INDICATE BB OR SB ?
Old Feb 23, 2008 | 02:42 PM
DZRick's Avatar
DZRick
Old Feb 23, 2008 | 03:18 PM
Greg's Avatar
Greg
Just another Corvette guy
i thought so
Me too, of course....
Old Feb 23, 2008 | 04:16 PM
427SIXPACK's Avatar
427SIXPACK
Originally Posted by DZRick
OOOPS FORGOT THE VIN ON THE TRANNY CORRECT,
BUT THAT STILL DOESNT TELL YOU BB OR SB
Old Feb 23, 2008 | 04:24 PM
Ironcross's Avatar
Ironcross
someone said the U-joints were different. In what manner are different. Size?
Old Feb 23, 2008 | 05:48 PM
DZRick's Avatar
DZRick
Can't argue with you there.
Old Feb 23, 2008 | 10:22 PM
Corey_68's Avatar
Corey_68
I think he was talking about caps vs straps.
Old Feb 23, 2008 | 11:45 PM
AWilson's Avatar
AWilson
Well, there is more stamped on it, there is a 2 or 3 digit code.
Again I don't claim to know anything but just last weekend I identified my differential as probably being original this way because the information and dates match. I read what the NCRS book said and then found the referenced stamping on my differential. Seeing is believing. I can post a picture if someone thinks I am wrong.
My differential is stamped 1 AO 9 12 67 which translates to:
1 = shift-1
AO = 3.70:1 Positraction small block,
9 12 67 is the date
Small block designations for 68 and early 69:
AK;AL;AM;AN;AO;AP;AS
Big block designations for 68 and early 69:
AT;AU;AV;AW;AX;AY;AZ;FA;FB;FC
Old Feb 24, 2008 | 12:03 AM
  #33
DZRick's Avatar
DZRick
Again I don't claim to know anything but just last weekend I identified my differential as probably being original this way. I read what the NCRS book said and then found the referenced stamping on my differential. Seeing is believing. I can post a picture if someone thinks I am wrong.
1 = shift-1
9 12 67 is the date
Wow, that's some good info!
I've got to get a copy now, I knew about the date codes and the codes telling what gear ratio but I didn't realize they also identified bb/sb.
Thanks for the post.
Old Feb 24, 2008 | 12:10 AM
  #34
AWilson's Avatar
AWilson
Originally Posted by Mark_Milner
Gas line is single on the 435 hp but I cant' think of a difference on the 390 and the SBC. In midyears, there was a difference in length so that the gas line ended at a different spot on the frame and had a slightly different angle in midyears, but I don't think that occurred in the 68.
My SB 327 350hp had a return line, so a double.
NCRS says: L88, 400HP and 435HP (all Holley-equipped) cars have only a single line.
Old Feb 24, 2008 | 12:34 AM
  #35
AWilson's Avatar
AWilson
Per NCRS:
Tachometer redlines for BB are:
5600 for 390 and 400 hp
6500 for 435 and 430 hp
power steering pumps:
Pumps on the 427 have a neck that is wider at the bottom than at the top and blends gradually into the body. SB have a rounded neck that extends forward of the pump body.
Emmission labels were on radiator in early 68 then it moved to the firewall above the master cylinder.
SB have a code; T,B,U,.
BB CODES ARE ; F;W;B;M;B;V;M
front spring codes:
SB = HS, HT
BB = HU, HV,
all F-41 = EA
only 427 had a rear sway bar.
Thats all I could find that wasn't engine related.
Old Feb 24, 2008 | 02:06 AM
  #36
international blue's Avatar
international blue
Differentials are big block specific. The code for a 3:70 rear is different for a 327 car versus a 427 car, and certain differentail ratios were SB or BB only. In addition certain ratios were L-88 only. The rear carrier is the toughest thing to change out in my opinion.
Transmissions do not indicate the engine options, but 435 cars required close ratio transmissions which were not required on the more pedestrian L36 or L68 427's. The transmission must be an M21 for a 435 car, but any engine could get the M21. I am not sure when the M40 Automatic became available with the 435 cars, so if anyone has that date I would be very thankful! I know it came to the L-88 after the strike in 69, but when did the L71/L89 cars get it?
Old Feb 24, 2008 | 07:09 AM
  #37
AWilson's Avatar
AWilson
For instance a 4.11 gear SB is code AP. The same gear in a BB is code FB.
