74 vette engine swap
Old Feb 24, 2008 | 10:10 PM
Cvman74's Avatar
Cvman74
Default 74 vette engine swap
Hi all, I have a few questions that I'm sure you've answered before. I currently have an L-82, and want to swap to a big block, I know it will bolt in. and I need to change brackets for alt, ps, a/c. but will I be able to use the same pulley on the p.s..What about front springs?. When I check at the local parts house they pull up the same number for the springs as the small block..also with the radiator..and also the B.B. has an edelbrock rpm air gap will this fit under the stock hood?. I really appreciate the help.
