Carpet Grommets
Old Feb 25, 2008 | 11:21 AM
70Yellowbird's Avatar
70Yellowbird
Default Carpet Grommets
My '70 has original carpeting that needs replacement. Can the rubber grommets in the floorboards be removed without destroying them ... and perhaps reuse? If so, how do I get them out? Thanks.
Old Feb 25, 2008 | 11:32 AM
wallifishrmn's Avatar
wallifishrmn
Buy new rubber grommets--they are only $12-15 for 9. I tried using some of the old ones (you can) the problem is they are 36 years old and aren't flexible & pliable like the new ones. Use new ones, spray them with silicone (inside and outside), and use a blunt tap to push them in (silicone inside allows you to pull out the tap and not pull out the grommet.
Old Feb 25, 2008 | 01:39 PM
wcsinx's Avatar
wcsinx
Seal up the holes IMHO. Those grommets are better at letting water in than out.
Old Feb 25, 2008 | 11:29 PM
ngroat7007's Avatar
ngroat7007
That was my plan
Old Feb 25, 2008 | 11:45 PM
DvBoard's Avatar
DvBoard
Do this .
Old Feb 25, 2008 | 11:56 PM
Yankees031's Avatar
Yankees031
St. Jude Donor '08
I didnt seal them yet but I am going to.
Old Feb 26, 2008 | 10:33 AM
70Yellowbird
Default Carpet Grommet Removal Question
Thanks for the advice ... I've never had a leak problem in that area.
Has anyone removed their grommets without cutting them out? How?
Old Feb 26, 2008 | 10:46 AM
wcsinx's Avatar
wcsinx
You probably just never noticed it because you don't have steel pans. When I pulled up my carpet, the pans were badly rusted in a radial area centered at the plug. There were no leaks from above, so the only logical conclusion is the water came from below.
I ground out the rust, welded in a patch, then sprayed rubber undercoating top and bottom. No more drain hole, no more rust
Old Feb 26, 2008 | 11:05 AM
Duke94's Avatar
Duke94
Pinch them on the other side with pliers and start pushing them back through the holes.
Old Feb 26, 2008 | 12:22 PM
70Yellowbird
Hi, I just checked your profile ... got a big chuckle out of your 'shade' of brown.
Are you describing the drain plug almost level area of your pans (close to the seats) or where the grommets go through the carpeted sloped area under your feet when your legs are fully stretched out, or both?
Old Feb 26, 2008 | 12:42 PM
wcsinx's Avatar
wcsinx
I don't think the steel pans have the latter. Or I'm just forgetting about them. It's been 7 years since I fixed mine. I only recall the one big one right smack in the middle.
Old Feb 26, 2008 | 01:16 PM
wallifishrmn
You have switched from grommets to drain plugs--which is it. The grommets --just pull on them and they come out--if you don't replace them there is nothing to hold the top of the carpeup. No I didn't use any adhesive--don't need any if you use the rubber grommets..
Old Feb 26, 2008 | 01:23 PM
wcsinx's Avatar
wcsinx
Yeah, I dunno. I really don't think I had them which is why I assumed he was talking about the rubber drain plug.
Old Feb 26, 2008 | 02:21 PM
70Yellowbird
Just to be clear ... I didn't intentionally switch ... I mentioned the drain plugs in one of my followup posts because I suspected that was what was described in a reply to my original thread about carpet grommets ... I'm not sure how 'clear' this is after reading it myself. I'll try the 'pinch and push from the bottom side with pliers' technique. If they break or are no good, I'll buy new ones. Thanks for all your help.
Old Feb 26, 2008 | 03:24 PM
wcsinx's Avatar
wcsinx
My apologies for muddying the waters. Now I have to look when I get home. But I'm 99% sure I don't have those things.
Old Feb 26, 2008 | 04:19 PM
70Yellowbird
If you carpeting was replaced ... by a previous owner, perhaps they didn't bother to reinstall grommets. Check out the passenger side firewall just above the deflector plate. My '70 has 3 grommet holes there that you should be able to feel with your finger. I'm not at all familiar with your model year ... but another member can help if you really want to know.
Old Feb 26, 2008 | 06:13 PM
Red70vette's Avatar
Red70vette
I tried unsuccessfully to remove these gromets. I soaked them in silicone, used a pliers, massaged them, talked to them and spend way too much time trying to save them. Finally my Sicilian took over and I ripped them out and bought new ones.
To Carpet Grommets
