Turn signal switch.
Old Feb 26, 2008 | 10:51 AM
Merlinhaggard's Avatar
Merlinhaggard
Default Turn signal switch.
I have a 68 coupe.
My freggin turn signal switch isnt holding in postion.
The tab that holds it to 1 side or another is worn down..
Heres the question: Ive seen just the cam for sale. Anyone try one of these?.
Old Feb 26, 2008 | 03:08 PM
Blue68's Avatar
Blue68
St. Jude Donor '08
The turn signal switch is a 67,68 only part. There have been some people who have adapted a switch from other vehicles but I do not have the specifications.
I just bought a turn signal switch from Lectric Limited for my '68. You might give them a call and see if they have anymore.
wayne h.
Old Feb 26, 2008 | 03:15 PM
Merlinhaggard
Thanks Wayne. I guess I could have just called you..
Old Feb 27, 2008 | 09:20 AM
Merlinhaggard
Heres the cam..
Anyone ever replace just a cam and how do I remove the old one?
http://cgi.ebay.com/ebaymotors/67-68...3286.m20.l1116
Old Mar 1, 2008 | 11:06 AM
stev5ko's Avatar
stev5ko
I had the same issue on my 68 and tried to do a cam only swap.
It did not go on very easily and caused other electrical probs. I would highly recommend that you purchase the entire switch from lectric unlimited.
I got mine two months ago so they should still have some. Make sure that before you start the swap get under the dash and unplug the old switch and plug in the new and run it thru all functions (left/right and ck your brakes and flash)
There are alot of hit and miss issues with these switches but I think lectric unlimited is your best option.
good luck!
Old Mar 1, 2008 | 12:06 PM
wnmech's Avatar
wnmech
Here try these guys. I have purchased many column parts from them. They have the best prices I have found and use DHL for delivery and they are just A couple of old guys just in the business for fun.
http://www.corvettesteering.com/corvette%20parts.htm
Old Mar 1, 2008 | 09:54 PM
66CorvetteCoupe's Avatar
66CorvetteCoupe
Default 68 Turn Signal Switch
I went thru the same issue on my 68 when I was restoring it. That was 3 years ago and at that time no one made a replacement switch. I found out thru a lot of searching a switch from a 65 Pontiac Bonneville was the same switch with an extra set of leads for the side marker lights on the Bonne. Simply clip off those leads and presto same same. 67 switch is the same also. Good luck with your search.
Old Mar 3, 2008 | 07:55 PM
Q's 68's Avatar
Q's 68
Shee-Mar makes the Pontiac Bonneville Boyne switch. I purchased it two years ago and it looks/fits/works perfectly!
http://www.shee-mar.com/start.html
Old Mar 3, 2008 | 10:49 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Just changed mine out. Found a good switch on evelbay for $70 shipped. Some place in Alabama. ThePartsladi 334-493-1240
To Turn signal switch.
