70 vs 71 454
Old Mar 1, 2008 | 03:27 PM
kubesh's Avatar
kubesh
Default 70 vs 71 454
hey guys, was just wondering if you can realy tell the performance differance between the two? Is there a differance I have only drove the 71 so thats why I am asking
Old Mar 1, 2008 | 03:55 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
I think the only difference is the compression ratio, in '70 it is 10.5:1 and in '71 it is 8.5:1 .. if I'm not mistaken.
Old Mar 1, 2008 | 04:56 PM
Ray Y's Avatar
Ray Y
390 vs 425 HP.
Old Mar 1, 2008 | 05:02 PM
70454Convert's Avatar
70454Convert
Originally Posted by Ray Y
390 vs 425 HP.
1970 LS5= 390 hp
1971 LS5=365 hp, LS6=425 hp.
Old Mar 1, 2008 | 05:56 PM
dmayhew's Avatar
dmayhew
I can report that the 71 LtT1 had 40 HP less than the 70 LT-1 but in the real world ,on the street they both performed very close if the rear ratio were the same on both cars according to all I have read.
I assume the same can be said for the 454 cars.
As for value, the 1970 cars seem to bring more than 71 /72
This is due to things like very low production in 70 and the mystic of being the last of the high compression cars.
Old Mar 1, 2008 | 06:04 PM
Bullshark's Avatar
Bullshark
CI 5 & 8 Veteran
I have to respectively disagree.
I have owned two LT-1's. The 70 and a 72 which I recently sold. The 72 engine is identical to the 71 with the lower compression heads. The 70 with it's higher compression out performed the 72 hands down.
Bullshark
Old Mar 1, 2008 | 07:34 PM
joewill's Avatar
joewill
I thought 71 was the 1st year when 'net' horsepower was the basis of the horsepower rating, wheras 70 was rated 'gross' horsepower.. yes several have said that the difference is negligible. Gross and Net are about 20% different due to factoring in the accessories such as AC and Power Steering in dragging the power output.. Correct me if I am wrong?
Old Mar 1, 2008 | 08:14 PM
Bullshark's Avatar
Bullshark
CI 5 & 8 Veteran
Actually, only the 1970 LT-1 had 370 gross hp. The 1971 & 1972 both had 330 gross hp, but the 72 model was advertised with net horsepower (255) to comply with the new calculation standard.
Old Mar 1, 2008 | 09:02 PM
Red70vette's Avatar
Red70vette
The 70 was the last year of higher compression and minimal polution controls. Strictly stock the 2 factors made the 70 a better performing engine. That is not to say that you couldn't make some changes to a later model and improve it to perform the same or better.
Old Mar 1, 2008 | 09:51 PM
Ray Y's Avatar
Ray Y
Originally Posted by 70454Convert
1970 LS5= 390 hp
You are exactly correct. I was going for best case conditions. LS5 to LS5 the '70 wins.
Good looking '70 too!
Old Mar 1, 2008 | 10:01 PM
dmayhew's Avatar
dmayhew
Bullshark
No offence taken Bull Shark. My openion was based on info that I have read. Thanks for the input
David
Old Mar 1, 2008 | 10:04 PM
7T1vette's Avatar
7T1vette
Those three years [70, 71, & 72] are frequently a point of confusion as to HP numbers. Here's my attempt at a quick summary:
1970 was the last year for high compression engines; HP was rated with SAE gross method. 1971 had reduced compression engines (8.5 for base engines, 9.5 for hi-performance); HP still rated in SAE gross. 1972 used almost identical engines as 1971 BUT...they were rated in SAE net numbers [had to subtract the HP losses for auxillary equipment.
So, not only was 1970 a short-run model year, but it also had the highest horsepower engines possible. 1971's HP was down because of compression loss. 1972's HP was lower strictly because of rating method change.
Old Mar 1, 2008 | 10:26 PM
Zedder's Avatar
Zedder
Hey Bullshark...it's been a while since we talked about your cars. Man, I wish I knew the '72 was for sale, I loved that car! Hope you are doing well!
Old Mar 2, 2008 | 12:33 AM
Bullshark's Avatar
Bullshark
CI 5 & 8 Veteran
No offense taken Bull Shark. My openion was based on info that I have read. Thanks for the input
David
Hey David, I was just "respectfully" disagreeing. Offense wasn't even a consideration.
Hello Zedder, Yes, it has been awhile. Hope things are good for you also. Sorry, but I sold the 72 LT-1 to a friend here in St. Louis a few months ago. One of the St. Louis C3 sharks. It's hard enough keeping up with the ones I have now. He will give it a good home and it's still close by.
Bullshark
Old Mar 2, 2008 | 12:51 AM
early shark's Avatar
early shark
We need to correct some mis-information that has been stated above by previous posters.
Yes, there definitely is a difference between the three years that the LS-5 engine was offered as an option on the Corvette.
1970 LS-5 is 390 hp (gross) & 500 ft lbs of torque. Comp ratio is 10.25 to 1. Net hp is unpublished.
1971 LS-5 is 365 hp (gross) & 475 ft lbs of torque. Comp ratio is 8.5 to 1. Net hp is 285.
1972 LS-5 is 350 hp (gross) & 475 ft lbs of torque. Comp ratio is 8.5 to 1. Net hp is 270.
1970 engine uses TCS and re-calibrated distributor for emissions.
1971 engine uses CEC and re-calibrated distributor, for emissions.
1972 engine uses TCS and re-calibrated carburetor, distributor and A.I.R. emissions system. Timing specs are different from 1971.
Old Mar 2, 2008 | 08:30 AM
mstanton's Avatar
mstanton
Actual horsepower went down each year for all engines between 70 and 72:
71 LT-1 275 net (330 gross)
72 LT-1 255 net
71 base 210 net (270 gross)
72 base 200 net
Old Mar 2, 2008 | 09:34 AM
Bullshark's Avatar
Bullshark
CI 5 & 8 Veteran
72 LT-1 255 net
72 base 200 net
Mark, what changed from 71 to 72 on the LT-1's that resulted in a 20 hp loss? I can't think of anything except the T.I ignition or possibly timing and that doesn't count in my way of thinking.
To 70 vs 71 454
