paint question
Old Mar 4, 2008 | 06:20 PM
britvette's Avatar
britvette
Default paint question
Could someone suggest a website that will give basic DIY auto paint details . My dad is looking for info to fix up his truck (daily driver) is retired and so on a budget and looking to do the work himself so basic how to info is what he is after - TIA
Old Mar 4, 2008 | 06:50 PM
Durango_Boy's Avatar
Durango_Boy
http://www.hotrodders.com/
Old Mar 4, 2008 | 08:26 PM
britvette's Avatar
britvette
Thanks , I will take a look
Old Mar 4, 2008 | 08:48 PM
hicswa's Avatar
hicswa
www.Paintucation.com
Danny
Old Mar 4, 2008 | 09:11 PM
britvette's Avatar
britvette
Thanks again , I will send him the links - will give him a place to start - thanks guys
Old Mar 4, 2008 | 09:31 PM
jds68stang's Avatar
jds68stang
One suggestion I can offer is avoid the black urethane if he was considering black as a color. They told me the main complaint w/ it was it kinda has a slight brown tinge in the sunlight, well it does, it's more than slight and I regret using it on my truck now.
I wet sanded w/320 and primed with Duplicolor spray cans prior to painting, (about $50.) I wet sanded primer w/ 400, thats kinda light, 320 is better for a good adheasion (so far no problems).
I did it peice meal, cab and bed first as my booth was a primitive homemade deal and its easier incase you have any problems. Dust and bugs are the main concern for anyone not using a good booth, tweezers are good to have handy as well
Learning how to tell when the first coat has "flashed" is very important before adding the second coat, 3rd coat.
Don't let a heavy cloud of overspray build up to much in the work area, its dangerous and I've been told it can flash fire, have plenty of ventilation.
Hang a chain from the exaust system to the ground, I learned this after the fact, has to do w/ static disipation. Also wet down the area before shooting the job, it holds down and catches some airborn dust.
A decent paint should run around $300-350 from last years quotes I got. He should find all he needs to know on the net for extra tips.
Before he starts spraying the truck, have a large piece of cardboard handy to adjust the gun on first. Definatly a good respirator and full body covered.
Painting a car is a fun, rewarding experience, if all goes well
Old Mar 4, 2008 | 11:57 PM
Hooked on Vettes's Avatar
Hooked on Vettes
Go this site. It's run by an auto painter.
http://www.autobodystore.com/home.shtml
If your dad plans on using base coat clear coat paint, he needs to use a full respiratory setup. The paint fumes are toxic.
Old Mar 5, 2008 | 12:49 AM
rajsid's Avatar
rajsid
Try this..
http://www.kustomkulturelounge.com/forum/
To paint question
