Guys !
I was able to remove the 1980 dash from my vette.
It was taken out before since the previous owner repainted it to match the body paint.(Burgandy).
Boy 'o boy did I do some pullin' and a bit of twisting !
I wasn't scared since I know I'm getting it replaced. It cracked and broke at some places....
Is there any tips you guys can give me to INTSALL the new one coming in ?? Its gonna be tight !!!
Remove the A-pillar trim for more room, and you'll want to pull the center upwards, bowing the dash, so the ends go in first. With it bowed, you should be able to get the ends down into position before getting the center section down, and then you're in.
Some people say to let it sit in the sun (if you have any) to warm up and become a little more flexible. DB is right, try to hump it up in the center, don't try to bend the ends.
Regards,
Alan
Besides the above good suggestions, if your new dash was like mine it had NO holes in it anywhere. I had to drill out all the hole and make sure evyerhting fit carefully. The foam they are made out of can take a good screwing once. If you screw up (pun intended) you will just elongate a hole.
So before screwing anything into it, make sure you are on the money.
And if you don't have the sun. A good hairdryer or careful application of a heatgun on the side 'wings' that go by the a pillar are a must. And amen on making sure all your screw holes are predrilled for all your instrumentation and glove box. When I installed mine, the fitment was off quite a bit on some items especially the side air vents, the speedo tack housing. I had to heat it all up and reform pieces for a better fit. Good luck, mine was a trial in patience.
I heated the original dash pad on my 68 thoroughly for removal and installation using a hair dryer. As DB mentioned removal of the pillar trim gave me an extra inch which allowed me in bow the dash only slightly in and out.
From: GA "When I grow up, I'm gonna get a Trans Am and run from the cops". Direct quote from my 4yo son.
Phil, are you going to redo the speedometer to the 160 mph upgrade while everything is apart?? I've seen some on here that have been done. Definitely cool!
Guys !
Appreciated !
Phil
Advice: Wait until warmer weather hits to install it. Plastic parts expand and contract and it'd be a shame to crack the new part. At the least, try to get some heat around before doing the install and make sure to keep the new part inside prior to installation.
i wish i would have never pulled mine, it basically disinergreated upon removal. the aftermarket one just doesnt fit like the original, me and the dremel became friends
