First problem with new car. won't start.
it seems like a short, or a blown fuse. i don't have a shop manual yet, and would appreciate any suggestions or head starts.
Then you need to check the wiring to the starter. I don't see how wiring the radio would have anything to do with the starter but you need to see if there is power going to the starter. I suggest a shop manual and an Assembly Manual. They will help you in your future adventures.
sorry. i sometimes suffer from "they-know-what-i-mean-itis"1980. auto L48. 41,600 miles. i put on about 200 miles since I bought it yesterday. runs fine.
all electrical stuff works fine, headlamps (won't open cause the engine isn't running, but they light up), interior lamps, radio had a fuse blown, but i replaced it and it works fine now, voltage dial on guage cluster reads around 12 volts. battery is charged. lights weren't on or anything. stopped at a grocery store at the end of a 25 mile drive, and when i got out, it acted like the starter isn't connected to the rest of the car. that's why i thought 'short' or 'fuse'.
where is the starter, on the bottom of the engine, near the front or the back?
So I have this straight; you replaced radio, fixed fuse at radio, then drove 25 miles, before it would not start??
I know it sounds silly, but it has happened here a couple times that the only thing keeping the car from starting was still being in gear.
edit: added more information about connector.
This is what it looks like, it sits next to the shifter, under the shifter plate. Just jumper across the two purple wires, and try and start the car.
I would have bet this was your problem but see it wasn't solved by the jumper. Did you get the car home or is it still stranded? Was it warm out? Almost sounds like classic heat-soak...Good luck
it's at home in my garage. I'm looking at it now. I also just went to the parts store and bought a chiltons manual. at least it can get me through this until i can buy a real shop manual.
i'll check out the starter now.
http://forums.corvetteforum.com/show....php?t=1949920
An offer that is timely for you, as his information is superior to what you will find in the Chilton!
Let us know what you find.
does anyone know what that green wire, clear-ish connector is? i can't find anything to connect it to. it comes out of the wire bundle driverside of the center tunnel, right next to the shifter. it's just one wire.
edit to add: thanks, dannyman. yeah, i asked for it last night and they came in. i was just about to go to that thread again and say thanks. he does a good service for the boards.
