Astro ventalation
Old Mar 7, 2008 | 10:19 AM
markbett's Avatar
markbett
Default Astro ventalation
Does anyone know how the rear vent works? (1969 coup) I see an air actuator with a vacuum hose, but what triggers it to open or close?
Old Mar 7, 2008 | 12:41 PM
Mike Ward's Avatar
Mike Ward
With the engine running, set the heater to full cold and the other selecotr to anything but off. The door should open.
Old Mar 7, 2008 | 03:07 PM
markbett's Avatar
markbett
Thanks, mine is stuck in the open position, one more thing to add to the list
Old Mar 7, 2008 | 05:52 PM
Alan 71's Avatar
Alan 71
Markbett,
Is there ever not a list?
Regards,
Alan
Old Mar 7, 2008 | 06:16 PM
RunningMan373's Avatar
RunningMan373
Originally Posted by Alan 71
Markbett,
Regards,
Alan
No.
Old Mar 7, 2008 | 09:46 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I thought if you selected any vent position with the temp to full cold the doors stayed open. Then if you wanted to add any heat, the doors go closed to keep heat in. At least that is how I think it works on mine. Its been a long time since I have played with it. Any heat dialed/added closes the vent doors.
Old Mar 8, 2008 | 12:18 AM
Ray Y's Avatar
Ray Y
I agree and so does the GM service manual, for a '70 anyway. Just rebuilt mine while doing a full interior revamp.
Old Mar 8, 2008 | 12:56 AM
Solid LT1's Avatar
Solid LT1
Rebuilt that vacuum system? your my HERO! I'm OK with headlamps/windshield system but, Astro Vent system and heater selector valve makes me CRINGE!
Old Mar 8, 2008 | 12:46 PM
Ray Y's Avatar
Ray Y
It really wasn't as bad as it looks to be, being a vert really helps for access. It was a forced repair to eliminate a Bubba fix. Previous owner thought it was necessary to plug the drain box holes and the tubes were missing; well guess where the water goes if you do this? Yep, right thru the astrovent doors into the rear interior. Now the drains are fixed and everything else was removed, de-rusted and painted, and re-installed. Just finished laying the last piece of Dynamat Extreme last night and the new Al Knock carpet set is due next week.
Old Mar 8, 2008 | 02:39 PM
markbett's Avatar
markbett
So then, there no way to close the vent as long as the temp selector is set to cold? No wonder mine stays open, I never turn on the heat. Should it be ratteling like a can of nails in the open position or does mine just need to be re-built.
To Astro ventalation
