Can someone please send me an assembly diagram of the lower
bearing assembly ? I have pulled the steering column out & found the bearing 1/2 inch out of the shaft. I think I have figured it out, but I think some parts are broken or worn.
I dont have a manual yet. What is the best one to start with & where can I get a copy.
Thanks for any help in advance.
After thought.
It has been converted to right hand drive, so the the information may not be 100% fix.
The bearing is a press fit into the plastic adapter.
The standard (non-adjustable) column has a coil spring behind the bearing adapter. The T&T column does not have a spring.
