Rear Ride Height
Old Mar 10, 2008 | 12:04 PM
ray3222's Avatar
ray3222
Default Rear Ride Height
How can I raise a C3 rearend approx. 2 to 3 inches to avoid scrapping the pavement on uneven roads?
Thanks.
Old Mar 10, 2008 | 12:14 PM
1970 Dave's Avatar
1970 Dave
How is your rear spring and shock absorbers?
SEMPER FI--1970 Dave
Old Mar 10, 2008 | 12:16 PM
hicswa's Avatar
hicswa
Get shorter spring to trailing arm bolts.
Danny
Old Mar 10, 2008 | 12:19 PM
Maymyvetteliveforevr's Avatar
Don't mean to highjack this thread but I read once about the ride hight not being the same on the rear for Left and Right? Does anyone remember the title since I can't seem to find it in a search?
Old Mar 10, 2008 | 12:22 PM
GD70's Avatar
GD70
Danny
Shouldn't they be longer, or am I confused? A shorter bolt would bring the body down lower to the spring I would think.
Old Mar 10, 2008 | 12:26 PM
hicswa is correct.
Old Mar 10, 2008 | 03:17 PM
r44s's Avatar
r44s
Having the same problem and scraping the exhaust on my driveway I am awaiting my new rear spring. As odd as it sounds longer spring bolts will lower the car. Must be less tension on spring. Shorter bolts compress the spring more and raise the car. Also C3s have a tendency to be lower on drivers side than passenger side.
Old Mar 11, 2008 | 11:47 PM
clintwilson's Avatar
clintwilson
Default ride height
tighten the bolts will raise the ride height.
Old Mar 12, 2008 | 01:28 AM
rcread's Avatar
rcread
Nope, shorter bolts will raise your ride height. It may be counterintuitive to how you are thinking about it, but that's how it is.
Old Mar 12, 2008 | 04:05 AM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Yes, how is your spring? It may be time for a replacement rather than for fudging adjustments. Pics would be worth 1K words.
Old Mar 12, 2008 | 09:43 AM
jim2527's Avatar
jim2527
you'd think that but....
If oyu loosen the nut it takes tension off the spring allowing the car to lower because the spring in a certain sense has lower rate. The hweel/trailing arm pulls up on the bolt...a longer bolt allows the wheel/trailing arm to travel higher up into wheel well before it puts tension on the spring.
A shorter bolt catches the spring sooner resulting in the chassis being suspended sooner.
A longer bolt takes longer to catch the spring resulting in the chassis being suspened later.
Old Mar 12, 2008 | 11:20 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
I would look at your spring 1st with the car on the ground. If it's a steel spring and it's flat, than it should be replaced. Measure the bolts also. On a steel spring car, the bolt should be 6" long.
Old Mar 12, 2008 | 12:29 PM
GD70's Avatar
GD70
Thanks guys for clearing this up. I thought about this after I first posted my question and realized what happens.
Glenn
Old Mar 12, 2008 | 02:39 PM
vettekid333's Avatar
vettekid333
2024 C3 of the Year Finalist - Unmodified
My guess would be that this will raise the body but not the frame or the exhaust which sounds like what you want to raise.
Old Mar 12, 2008 | 04:06 PM
hicswa's Avatar
hicswa
The exhaust is attached to the back of the frame which will go up as the body goes up. My bad on my first post, the frame will go up as the spring is flexed up by using shorter bolts.
Danny
Old Mar 12, 2008 | 04:14 PM
Kid Vette's Avatar
Kid Vette
I always thought the body was attached to the frame. No?
Old Mar 12, 2008 | 05:46 PM
vettekid333
Duh, I believe you are correct. Guess I should have thought that one out a little before I spoke!
Good catch and cool name KID
To Rear Ride Height
Old Mar 12, 2008 | 09:06 PM
2manyvetts's Avatar
2manyvetts
Default Air Shocks
Would air shocks work ?
Old Mar 17, 2008 | 12:59 AM
clintwilson
short bolt = tightening existing bolts. They are somewhat adjustable.
Old Mar 17, 2008 | 03:26 AM
RunningMan373's Avatar
RunningMan373
Stock bolts are 6 1/4 in long, 9/16, fine thread grade 8 bolts, the shaft of which is actually 1/2" with a larger end that is threaded. replace with a 9/16" fine thead Grade 8 bolt with more threaded shaft, a nylock nut and a thin lock nut above it, if desired- nylocks shouldn't walk , you can then fully adjust the ride height by simply jacking the car up, takint the presure off the spring with a jack and adjusting the nut up for higher ride height, and down for lower.
