Help with my heads
Old Mar 11, 2008 | 09:39 AM
1stCorvette69's Avatar
1stCorvette69
Default Help with my heads
Well, now that I found out , From the Good people on this site ( And I Thank you all) that I indeed have a 350 truck engine from Canada in my 69 Vette. Now The Spark plugs are angled and do interfere with the Headers Someone bashed them in as to facilitate the plug removal and installation. Looks kinda Redneck engineering to me.. I wanna put on side pipes or at least another set of headers. Doe's anyone sell headers for this type of head ? Or must I change the heads? I know this is a Basic question for any corvette owner. But I have been away form American Iron for so long I Fergit.... Appreciate you help. Mark
Old Mar 11, 2008 | 09:46 AM
Durango_Boy's Avatar
Durango_Boy
I am a big fan of Hooker headers. I have the side mount headers and side pipes on my Vette.
Another thing to look into are short header plugs. They are designed for use with headers, and are less of a pain to deal with. I don't have any part numbers because I use standard plugs with my headers.
Old Mar 11, 2008 | 09:59 AM
1stCorvette69
Default short plugs?
Never heard of short plugs.. I guess I should get the casting #s off the heads and first find out if they are 202s I did want the bigger valves..
Old Mar 11, 2008 | 10:11 AM
Durango_Boy
I can get some part numbers from another member that has them on his car. Someone else might know too.
Old Mar 11, 2008 | 10:31 AM
1stCorvette69
Old Mar 11, 2008 | 06:40 PM
Solid LT1's Avatar
Solid LT1
Angled plug location on OEM 1969 Truck heads THATS FUNNY!
Old Mar 11, 2008 | 06:46 PM
1stCorvette69
Default angled plugs
I laddie, I forgot to mention Not the orig. engine I do belive it to be a later engine.
Old Mar 13, 2008 | 07:04 PM
1stCorvette69
Default help with my heads
I pulled the valve cover and got these # 3991492 They are Over counter, strt or angle plug, 64cc, 157/62cc ports. Can anyone tell by these # if I have 2.02 intake valves?
Old Mar 13, 2008 | 07:21 PM
sdonnelly's Avatar
sdonnelly
Looks like you have all the info offered on Mortec 3991492....70......350..........LT1,Came l hump,accessory holes,64cc, straight plug
3991492....70-up................over the counter,Camel hump,64cc, straight or angle plug
So I don't know how you know with the heads on.
You should be able to ask the header manufacturer if their headers will work with your heads/plugs. They may tell you yes, regardless, just to sell another pair, but you could ask.
Old Mar 13, 2008 | 07:28 PM
ghoastrider1's Avatar
ghoastrider1
while trying not to dismiss the importance of the 202 intake valved heads, its the exhaust size that makes the numbers jump on those older chevy heads. You have the good ones,.
Old Mar 13, 2008 | 07:42 PM
1stCorvette69
Default Found my answer..
I google the part # and found my answer. they are service replacement heads and have 2.02 valves They are high performance heads.. WOW. ) Now if I can find a set of headers that fit right ...???Thanks for the Replies... Goin to Charlotte motor speedway next month , Hope to see some Vette owners there...
To Help with my heads
