A/C to Header mount question
Old Mar 13, 2008 | 03:50 PM
Drunken Peacock's Avatar
Drunken Peacock
Default A/C to Header mount question
I'm putting new headers on and wonder how you mount the A/C to the new headers. Some bubba before me put on a long bolt with a whole bunch of nuts then what looks like the original bracket and another nut on it. It looks like kaka.
Old Mar 13, 2008 | 04:30 PM
69monzacpe's Avatar
69monzacpe
Usually when you buy headers, the header supplier can supply brackets for A/C, Alt, etc if they know what your putting the headers on.
You may be able to get them from Summit too.
Sounds like someone took the cheap way out, but like you said, it looks like fido's butt.
Good luck!
Old Mar 13, 2008 | 06:39 PM
Scott Marzahl's Avatar
Scott Marzahl
What year are you working on, for some you'll have to build or machine spacer(s) to achieve the same thickness as the original manifold.
Old Mar 13, 2008 | 06:43 PM
timscott's Avatar
timscott
Summit sells the part you need. Part # wlk88304. Cost is about $20 or so.
Old Mar 14, 2008 | 03:50 PM
Drunken Peacock
That's awesome guys! Thanks. I currently have a Turbo on my 1980 and I'm pulling it off next weekend. The piping was pretty crappy. I've got a new carb and manifold and Hedmen Elite ceramic coated headers. With all that clean and shiny stuff I'd hate to put the bubba solution back in there.
Old Mar 15, 2008 | 08:34 AM
marshrat99's Avatar
marshrat99
I went the option of using a short piece of pipe instead of shimming out the bolt with nuts. You could get a nice piece of stainless steel piple that should look great. When I installed my Hedman's on my 79, I have the bracket from Summit suggested above but couldn't figure out how to make it work and simply gave up. Maybe I had too many while I was attemping the installation?
Old Mar 15, 2008 | 08:43 AM
djcwardog's Avatar
djcwardog
Default Pipe
I used the pipe trick also - looks good.
Old Mar 15, 2008 | 09:49 AM
guitarcrazy02's Avatar
guitarcrazy02
I'm using the pipe, too.
For the car
To A/C to Header mount question
