headlights won't go down?
Old Mar 16, 2008 | 08:08 PM
keifus's Avatar
keifus
Cruising
Default headlights won't go down?
Hey,
Is there a way to lower headlights or which vacuum hose do i un-plug so they will go down?
Having a bit of a problem. Thanks for your time fellow vet owners
keif~
Old Mar 16, 2008 | 08:19 PM
Gordonm's Avatar
Gordonm
Reach up from underneath and pull on the "knee" of the joint. This will release them and the lights will come down. They will come down quite easily this way. No picture but think of the action as a knee operation and you will get the picture.
Old Mar 16, 2008 | 08:29 PM
keifus's Avatar
keifus
Cruising
Default knee?
ok does this knee happen to be under each light or does this "knee" happen to be in the middle of the lights, this is on a 81 vette.
thanks for your time kind sir!
keif~
Old Mar 16, 2008 | 09:09 PM
Carl Granquist's Avatar
Carl Granquist
I don't have an '81 but I'm guessing the mechanism is similar. Can you spot anything that looks like this?
File Type: psd
Last edited by Carl Granquist; Mar 17, 2008 at 02:38 PM. Reason: Picture format. Meant to post this way originally.
Old Mar 16, 2008 | 09:51 PM
Gordonm's Avatar
Gordonm
It will be under the headlights right in the middle. It is in the shaded part of that picture that is shown
Old Mar 16, 2008 | 11:51 PM
7T1vette's Avatar
7T1vette
Buy them dinner first???
Old Mar 17, 2008 | 12:39 PM
keifus's Avatar
keifus
Cruising
Thanks a lot for the advice. Worked just like you said. Never knew that. Thanks again for the knowledge. I take it you can also put them up with that method? But again thanks!!
keif~
Old Mar 17, 2008 | 01:11 PM
GD70's Avatar
GD70
keif~
Just push up the light assembly and grab the hedalamp cover edge from above and lift.
To headlights won't go down?
