Picked Up My New Engine Today!!!
Old Mar 16, 2008 | 09:18 PM
Jeffery73's Avatar
Jeffery73
St. Jude Donor '08-'09-'10-'11-'12-'13
Default Picked Up My New Engine Today!!!
It's a GM Performance 330HP 350 with a Performer intake. It should be a definate improvement over the L-48.
Old Mar 16, 2008 | 09:25 PM
BritewhiteC3's Avatar
BritewhiteC3
Sweet looking, Are the heads Vortec Heads ? Aluminum ?
Old Mar 16, 2008 | 09:27 PM
RMVette's Avatar
RMVette
Sweet!
What are you doing posting...you should be bolting it in the car by now!!
Old Mar 16, 2008 | 09:28 PM
Jeffery73's Avatar
Jeffery73
Yes, they are Vortec iron heads. I looked into getting the ZZ4 engine with aluminum heads but the budget wouldn't allow it.
Old Mar 16, 2008 | 09:31 PM
Jeffery73's Avatar
Jeffery73
Originally Posted by RMVette
Sweet!
Your probably right but we got back from Summit at 1pm and I worked from then until 8pm. It's been a long day.
I'll get back out there tomorrow night. I'm hoping to have the swap done in a month or so. I'm going to rebuild the trans and do a lot of cleanup under the hood while the motor is out.
V77Vette's Avatar
V77Vette
xtra 140hp will make the old gal feel like she should!
you not going to put new(electric) dizzy on her?
Old Mar 16, 2008 | 09:32 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
Looks great, now get her in the car.
Old Mar 16, 2008 | 09:33 PM
Jeffery73's Avatar
Jeffery73
I have a Crane electronic unit in the dizzy. I would convert to HEI in a second if I didn't have to worry about the tach drive. The tach drive HEI's are kinda expensive.
Old Mar 16, 2008 | 09:50 PM
pbcanney's Avatar
pbcanney
yummy!
Old Mar 17, 2008 | 06:47 AM
RunningMan373's Avatar
RunningMan373
Perfect motor for that car. That's useable power, the kind you can modulate with your right foot in a turn, -congrats
Oh, and by the way.... Saweeeettt!!!!!!!!
Old Mar 17, 2008 | 10:22 AM
69camfrk's Avatar
69camfrk
From: GA "When I grow up, I'm gonna get a Trans Am and run from the cops". Direct quote from my 4yo son.
I had one of those in my '80 I used to have. It was a great motor. With the stock gears, the car pulled really hard on the interstate.
Old Mar 17, 2008 | 10:42 AM
Scottys78's Avatar
Scottys78
Very nice
Cant wait to see it in the car
Old Mar 17, 2008 | 11:14 AM
in2fun's Avatar
in2fun
That looks nice !
Old Mar 17, 2008 | 12:56 PM
GD70's Avatar
GD70
Awesome! You're gonna have some fun! The only thing I would do is paint the block chevy orange, otherwise looks great.
Old Mar 17, 2008 | 01:17 PM
PETKAH's Avatar
PETKAH
Got the same engine a few months ago - nice to have an engine that is fast and dependable. As stated, do paint it orange to go with the era.
On my '70 with a LT1 Hood I could not use the Q Jet because of clearance issues - had to go with a smaller Holly. Are you OK with hood clearance? PS: Per other post you can get a HEI with Tach drive from Star Performance and others under $200 (search other threads because it has been discussed.)
Old Mar 17, 2008 | 01:37 PM
Jeffery73's Avatar
Jeffery73
Hopefully I will be ok on clearance. It looks like the Performer is about 1 1/2 inches higer than the stock intake. I'm planning to use a low profile air cleaner so hopefully it will fit.
Thanks for the info on the distributor. I'll look into it.
Old Mar 17, 2008 | 01:47 PM
PETKAH's Avatar
PETKAH
Just FYI I used the GM intake which might be higher than the one your using. Also, used a low profile air cleaner. Keep up the good work!
To Picked Up My New Engine Today!!!
Old Mar 17, 2008 | 03:09 PM
pbcanney's Avatar
pbcanney
from somewhere else:
Dual Plane:
Edel Performer (2101):
Front: 3.50" Rear: 4.60"
Performer Air Gap (2601):
Front: 3.72", Rear: 4.92"
Edel Performer RPM (7101):
Front: 4.20", Rear: 5.25"
Edel Performer RPM Air Gap (7501):
Front: 4.20", Rear:5.25"
Holley Street Dominator (300-36):
front 4.44", rear 5.33"
Weiand Stealth (8016):
front: 4.18", rear: 4.50"
Weiand Action Plus (8000):
front: 3.75", rear: 4.63"
Weiand Action Plus (8004):
front: 3.50", rear: 4.00"
Old Mar 17, 2008 | 04:55 PM
spedaleden's Avatar
spedaleden
Old Mar 17, 2008 | 08:57 PM
Jeffery73's Avatar
Jeffery73
Dual Plane:
Thanks for the info. I wonder what the stock manifold is. I picked the Performer because of concerns about height and because I'm looking for more low end torque. With all of the cops in this town, high end horsepower doesn't do you much good.
