Hooker Header Gasket
Old Mar 18, 2008 | 04:59 PM
My70's Avatar
My70
Default Hooker Header Gasket
I need to replace the header gasket on the passenger side of my 70 vert (350) Any helpfull hints ? Best place to get the gasket ? Thanks
Old Mar 18, 2008 | 08:31 PM
blue427's Avatar
blue427
I use Mr. gasket Ultra seal,never a problem. as far as tips,remove 1st and last bolt and put in 2 studs,then when you take rest of bolts out and replace gasket just put the header on studs,slip gasket on,tighten studs with nuts then put rest of header bolts in.The bolts line up much easier that way
Old Mar 18, 2008 | 09:57 PM
sperkins's Avatar
sperkins
Mr. Gasket or Percy's. Autozone carries the Mr. Gasket:
http://www.autozone.com/R,APP1048268...ductDetail.htm
Old Mar 18, 2008 | 09:59 PM
redcruz1120's Avatar
redcruz1120
St. Jude Donor '09
Get a copper header gasket!!!!!!
Old Mar 19, 2008 | 01:02 AM
RIJVETTES's Avatar
RIJVETTES
Go for a more durable copper gasket. Summit has a real good house brand for about 50 bucks.
Old Mar 19, 2008 | 03:53 AM
donnietcb's Avatar
donnietcb
call bassanni they have the best header gasket i have ever seen.
stainless with inserts that can't blow out they run about $50
donnie
Old Mar 19, 2008 | 02:57 PM
C3 4ME's Avatar
C3 4ME
Mr Gasket Ultra Seals on mine, and no problems. You don't need studs on the front and back, just don't take the bolts all the way out, that's how I did mine. Just remember to retighten them after some miles.
Old Mar 20, 2008 | 10:16 AM
My70's Avatar
My70
Just so I get this right, you back out the first and last bolt (and leave them in to hold the header) then remove all of the other ones and slip in the gasket ?
Any order in tightening the bolts ?
Will any of the old gasket need o be scraped ?
Old Mar 20, 2008 | 10:42 AM
worship79's Avatar
worship79
Just ordered mr. gasket myself, should be in tomorrow. I got a tip to put RTV on both sides of the gaskets, is this a good tip?
Old Mar 20, 2008 | 10:48 AM
Gordonm's Avatar
Gordonm
Use the high temp red RTV. I have used this on mine and reused the gaskets many times over without a leak.
Old Mar 20, 2008 | 03:54 PM
My70's Avatar
My70
I went into Summits website, didnt see any copper Header gaskets and the most expensive one's they had were under $20.00
Old Mar 20, 2008 | 04:45 PM
blckslvr79's Avatar
blckslvr79
Ordered mine on Tuesday for my Hooker side pipe install this weekend.
Had them in hand UPS the next morning before noon! That's Service!
Summit brand-part number#111406 1.50x1.44 small block chevy
Made in USA stamped H.C.G. They look like high quality and are very heavy-solid copper.
$29.95
On a side note, I've used the Mr. Gasket before with mixed results.
I'd never use them again.
To Hooker Header Gasket
