If there has never been a bolt in there it could be filled up with crude. The hole goes right into the wheel well and a lot of junk or rust could be built up in the hole. You might try to run a tap through the hole.
I cleaned out 37 years of carpet glue and crud and the bolts thread in.
David,
Thanks for the offer but I'm good in the bolt department. I ordered 4 for the lap belts from my local Chvey dealer yesterday.
