Maybe this should be int he "Tech" section, but......Can anyone tell me what is the correct material used on 69 seat backs? Were they a kinda heavier black fiberglass or where they a lighter plastic? Thanks, john
anybody to second this opinion? I have 2 nice ones that are a heavier black fiberglass material, just want to make sure they are the right ones for a 69, thanks, john
John,
I'm not quite sure the originals were fiberglass, based on the way they degrade with sharp-edged cracks, maybe ABS? They are definitely heavier than the repops with a dark color (charcoal).
Originals should be fiberglass. ZIP is advertising they have fiberglass seat backs, $55 each, in the current Corvette Fever issue. As far as I've seen most vendors sell plastic ones.
ok, now I'm confused..really...............anybody with an original car that can verify? The set I recently bought are a heavy fiberglass, very dense stuff, but the cracked up one on my 69 looks like plastic?
I don't know if I'm helping or adding to the confusion ... I have an original 70, and the seat back is a glossy black, has a fiber texture, but resembles ABS. On the rounded edges where the screw holes are located, I can see short fiber strands, and just above center is the raised number 3974092. So what is it really?
The 68-69 NCRS Tech Information Manual calls them 'plastic'. So ????
Regards,
Alan
Technically, fiberglass is plastic, sometimes called FRP, fiber reinforced plastic.
The seat backs do appear to contain fibers and look a lot like fiberglass from the body of the car...but as they degrade they develop sharp cracks all the way through, unlike fiberglass.
