I have been thinking about Steeroids, does you're car feel like a modern car with R&P steering now and how is the steering effort, does it feel like real power steering?
There is no question that the car steers easier and more responsive. I did not replace my original pump so I am still using the 30+ year old original. I expect that with a new pump I would even notice more improvement. Steering is quicker, the turns lock to lock are less than with the original system. Because at the same time I installed the Steeroids kit, I also installed the monospring kit so I made two major changes at the same time so it is difficult to know what impacted the handling most.
Remember that even though you have fewer turns lock to lock, you also have a larger turning circle. You steering rate is the same.
at least mine was, there may be more than one rate.
I have adjusted the steering stops on my control arms to give me the same turning radius that I had with the original system. I did not mention that in my document as I knew the majority would be using the original control arms.
