Help with color
Old Mar 27, 2008 | 10:44 AM
HT1663WB's Avatar
HT1663WB
Default Help with color
I'm having a hard time ordering a dash pad for this..1977 Coupe looks like light blue...code 272? Any help would be great.
Thanks, Bill
Old Mar 27, 2008 | 10:56 AM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
Is the trim tag code 272, there were 2 blues for 77 light & dark.
Old Mar 27, 2008 | 11:07 AM
Ganey's Avatar
Ganey
272 is dark blue interior. (272L leather)
(There are 2 Exterior blues Lt. 26 & dark 28.)
Old Mar 27, 2008 | 11:09 AM
HT1663WB's Avatar
HT1663WB
I just spoke with Willcox, they told me to just specify that it was 1977 blue. I just ordered a complete carpet set and an upper dash pad.
Thanks guys
Old Mar 27, 2008 | 11:27 AM
7T1vette's Avatar
7T1vette
If the dash color is significantly different from what you have now (fading of your parts, etc.), all is not lost. You can have some vinyl dye mixed up to match you old parts and re-spray the new one to match. Since the upper dash pad is new and uninstalled, that correction would be really easy. {Simpler than swapping dash pads; much simpler than re-dyeing all of your existing parts to match the new pad.}
Old Mar 27, 2008 | 11:47 AM
HT1663WB's Avatar
HT1663WB
Thanks for the info. I sent a picture to Willcox hopefully it will help.
To Help with color
