Is This Possible!!!!! Need Advice!!
Old Mar 29, 2008 | 07:09 PM
69 Convertible's Avatar
69 Convertible
Default Is This Possible!!!!! Need Advice!!
Long story short, have problem putting the shroud in, but I pried and pulled and finally got the lower shroud in the bolts of the radiator support. The bottom of the shroud is pass the crossmember maybe 1/2 inch if not a little more. Doesn't look right. so I went to my brothers house to use his 69 vert as referance. His shrouds sits above the crossmember. My question is: is it possible for the front of the vette to sag lower? I've had the vette up on jackstands for 8 months now. Could this be the reason why thing aren't lining up???? Tony
Old Mar 29, 2008 | 07:20 PM
Durango_Boy's Avatar
Durango_Boy
Yes it's possible. The lower side bolts on the core support actually hold the front clip up. I have seen people raise the clip by loosening these bolts, jacking up the nose, and tightening the bolts for the desired height.
Old Mar 29, 2008 | 07:34 PM
69 Convertible
I'm thinking of loosening all the related bolts that I have taken off and drop the car down on the ground to see if that will change anything. It's the only reason I can think of why I'm having such a hell of a time getting things back together. Radiator/shroud especially. Tony
To Is This Possible!!!!! Need Advice!!
