Headlights go up??
Old Apr 1, 2008 | 03:22 PM
Merlinhaggard's Avatar
Merlinhaggard
Default Headlights go up??
When I start the car the headlights go up.. My checkvalve has a vaccum comming from the intake. Is this the wrong vacuum?. Do I need a new check valve?
Old Apr 2, 2008 | 10:09 AM
Merlinhaggard
bump!
Old Apr 2, 2008 | 06:01 PM
Alan 71's Avatar
Alan 71
MH,
I'll ask 1 question and then try to answer. Do they stay up or do they come down after a few seconds?
Regards,
Alan
Old Apr 2, 2008 | 09:48 PM
Merlinhaggard
Stay up... They lock in when they go up..
Old Apr 2, 2008 | 09:49 PM
Merlinhaggard
have you noticed the forum working wierd the last couple of days?. Like the replys arent there, then they are. Wierd stuff?
Old Apr 3, 2008 | 09:59 AM
mdj21's Avatar
mdj21
did you check the over ride switch?
have you had the dash off recently?
Old Apr 3, 2008 | 10:14 AM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
When you start the car it has no affect on the headlights unless something is wrong with your switches. The engine is only a pump to pull vacuum. If the headlights are going up, it is probably one or two things. The headlight switch is bad or the override switch is engaged.
BTW - The check valve only prevents bleed down of the vacuum in the system.
This is all pending everything is plumbed correctly.
Old Apr 3, 2008 | 11:11 AM
Merlinhaggard
How do I check the override switch.
My HL switch is in and the OR switches are pushed in as well.
I dont know if its plumbed correctly.
Theres a vaccum from the intake going to the ck valve and two comming off the other side..
Old Apr 3, 2008 | 11:50 AM
mdj21's Avatar
mdj21
you should have an over ride switch down by your knees that is used to pop the head lights up with out turning them on so you can change bulbs or clean them, ect...
look for a long skinny **** (about 1/4"x1-1/4") down by your knees. can't remember which way is which, but push up or pull down on it and see if that fixes you problem. should be by your left knee.
Old Apr 3, 2008 | 12:01 PM
Merlinhaggard
The override is pushed in. Changes nothing..
Old Apr 3, 2008 | 12:18 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Here is how it should work.
The big line coming from the check valve goes to a storage tank to store vacuum. The small line goes to the switches. It usually splits under the dash for the wiper door. When you pull the headlight switch out it sends vacuum to the relay. The relay (vacuum operated) will signal the doors to open. The overide switch is between the headlight switch and the relay. When pulled down it does the same thing as the headlight switch, but does not turn the lights on.
Sounds like you are getting vacuum to the relays and it is opening the headlights. I assume the bulbs are not burning when you start the car.
Old Apr 3, 2008 | 12:19 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Pushed it is correct to close.
Old Apr 3, 2008 | 12:20 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Try this. Use some pliers and pinch the line going to the relays. (While the car is running) See if they close. there should be a t by them.
Old Apr 3, 2008 | 12:42 PM
Merlinhaggard
Im gonna try that. Thanks alot. Ill be back..
Old Apr 3, 2008 | 01:57 PM
Merlinhaggard
I made a new thread..
http://forums.corvetteforum.com/show...post1564847880
To Headlights go up??
