The lamps are only available as an assembly. You might try looking for some good used lamps and remove the lens or we have them new us made by Trim Parts.
CM5341-41684 1970-1972 Side Marker Light Assembly. Left Front 70-72 $53.09
CM5346-41686 1970-1974 Side Marker Light Assembly. Left Rear 70-74 $53.09
CM5340-41685 1970-1972 Side Marker Light Assembly. Right Front 70-72 $53.09
CM5345-41687 1970-1974 Side Marker Light Assembly. Right Rear 70-74 $53.09
[QUOTE=Willcox Corvette;1564829215]The lamps are only available as an assembly. You might try looking for some good used lamps and remove the lens.
I bought used side marking lamp at ebay and made from two bad one good.
The lens go out when you push it from the bulb hole, it glue to the housing with silicon.
Avner
I purchased my ('69) lens from this company. Also known as Au-ve-co. The lens don't have the correct markings, but looked the same and for me that was fine. Part #'s 9916, 9884. I think '71 lens are the same, maybe not.
Well, one thing is that from my experience the lenses are easy to remove. They are actually glued in with a clear rubber type glue. Just stick your finger in the hole where the light goes and push. The lens will just pop out.
