Lock Cylinder-1971
I purchased the car with no keys and the cylinder was not locked. I had purchased a new lock cylinder and matching door cylinders. Well, the other day I was trying to start the car while poking my head through the door and I accidentally turned it to lock. If there is anyone that can help me figure this out without going through a locksmith, it would be much appreciated.
Tim
Go to: www.corvettefaq.com
Click on Jim Shea's Steering Papers
Click on Corvette Steering Papers
Scroll down to the Standard Steering Column or the T&T Steering Column section
Download the appropriate Disassembly & Repair Paper #1
Download the appropriate Disassembly & Repair Pic #1
You should have complete instructions on removing and replacing the lock cylinder.
Some instructions say that you need the key and the cylinder in the RUN position. I am sure that you do not need the key to remove the cylinder.
Jim
http://jimshea.corvettefaq.com/wp-co...HornParts2.doc
If you have a T&T column this link may assist you with the telescope lock, steering wheel, and horn parts.
http://jimshea.corvettefaq.com/wp-co...&HornParts.doc
Jim
