window regulator gear
Old Apr 3, 2008 | 01:48 PM
jlaw68's Avatar
jlaw68
Default window regulator gear
has anyone ever used one of these as a replacement. if so could you install it with the regulator in the door or does it have to come out. and is it made out of quality material that will last and not tear up anything else?
Old Apr 3, 2008 | 06:31 PM
moosie982's Avatar
moosie982
Default check this out
http://forums.corvetteforum.com/show....php?t=1952683
Give this previous thread a look see, Peace,,,Moosie
Old Apr 3, 2008 | 10:23 PM
jlaw68's Avatar
jlaw68
thanks, i did a search but missed that one
Old Apr 4, 2008 | 08:29 AM
MakoShark77's Avatar
MakoShark77
St. Jude Donor '24-'26
OK, I read Moosie's thread and didn't find the answer I'm looking for. I was speaking to local Corvette Shop owner and mentioned that I needed to rebuild my left regulator. He said the job isn't that difficult to do, but he highly recommended using a replacement steel gear, NOT the stainless gear most venders are selling as a replacement. He says the stainless gear will chew up the gear on the motor.
Whats everyone elses opinion/experience with this?
Old Apr 4, 2008 | 08:51 AM
Ganey's Avatar
Ganey
The stronger than stock aftermarket gear is best. The issue w/ the SS gear repair piece is that you can expect the narrow teeth to cut into the motor gear. No special tools to remove assembly however remember that spring is stiff so be careful & watch out for your fingers.
Welding is needed to remove & install the gear.
gingerbreadman1977 did more than 1 topic & that was mentioned.
http://forums.corvetteforum.com/show....php?t=1944136
Old Apr 4, 2008 | 09:28 PM
terry82's Avatar
terry82
did mine 8 years ago with the ss gear .has worked well for me .
To window regulator gear
