handling car in the rain?!?
Take your time and respect it if you don't it can come back and bite you hard! I don't like the idea of a young inexperienced driver driving a vette but if you are going to drive it you have to get it safe(tires,brakes,steering) and learn how it handles in different conditions.
It isn't like anyone is driving on old hard Goodyear Wide Tread F70s or Firestone Wide Ovals F70s now. You probably have some decent radial tires unless you bought some no-name discount special. Remember that the only thing that keeps you in contact with the road is your tires and so you never cheap out on them. This is a MAJOR rule in motorcycles, and it is just as important in any high performance car.
My 100 mph runs on slicks were with a '66 Corvette, the same chassis as any C3 up to 1979. If it can run 100 in the rain on slicks, you can run 70 on treaded street tires. And as to horsepower, it had a 600 hp 427 in front at the time.
Saturday night I was coming home from Deerfield Beach, FL and it was raining on the turnpike. I was still running around 75-80 in the rain in the dark in a Camaro. You know, another rear wheel drive car with 305 hp in front.
And it gets worse. I picked up a rabbit, some guy in one of those new Pontiac sedans, and he got up to 110 in the dark in the rain with no handling hassles. I backed out as I decided it was too rich for my blood, meaning I didn't want to find an FHP in the median at that speed and not be able to see him first. It had nothing to do with a rear wheel drive car in the rain, as it was quite comfortable at that speed.
So if you are having problems, look at your suspension alignment, how much offset your wheels have (your avatar looks like custom wheels) and the tread pattern and depth on your tires. If your tires are old, they get hard and don't grip as well, so you might consider getting new tires.
Setting a bit more caster than normal helps to keep them pointed straight, although it makes turning harder, but with power steering, you really aren't going to have a hard time anyway.
Many alignment and tire shops in Florida want to align differently on left than right, to "correct" for the crown of the roads. Tell them to set it straight, the same on both sides, and that you only run on the interstate where there is no crown. That crown stuff is nuts unless you only run the older state highways in the middle of the state with a canal on one side. Everything else has little crown if any, as evidence by all the puddles you see built up in the road.
Until the late '80s, the C3s were driven a lot in the rain, and there was no big epidemic of crashes or lost control. Find out what on your car is not set right, and fix that. Then drive it all you want.
Life is too short not to enjoy the vette regardless of outside weather. I'm a driver not a collector. I got stuck in Chicago for a couple of years with only a C3 and a C4. I drove the C4 year round so a little rain isn't going to hurt anything.
And BTW, the OP asked for advice on how to improve handling in the rain, but did not ask for advice on how to improve parking in the garage
It must be painful to have a car of that value that doesn’t work in the rain. I’d try a different tire..
Only my $0.02 worth.
It must be painful to drive your car anywhere, having to be paranoid about the slightest bit of dust hitting it. I'm happy with my 77 that I can drive to work, on a date, to a baseball game or just out for a Saturday drive in the country without having to worry about it.
It's also rather sad that your self-esteem is so tied up in the price of your vehicle that you have to brag about it and belittle others on the basis of relative values.
My advice still stands: it's a car, not a sugar cube.
