Replacing new center gauge bezel
Old Apr 9, 2008 | 07:29 PM
Rob vette's Avatar
Rob vette
Default Replacing new center gauge bezel
Hello I would like to know if it is hard to remove the seat belt warning push button on the center gauge bezel as Im going to attempt this job soon .much appreciated thank-you
Old Apr 9, 2008 | 08:29 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Rob,
You can get instructions on how to remove this bezel off our web sit.
To remove the push button is pretty self explanatory once you have it out. The push button has a retainer and a spring. The button is installed in the dash bezel center before it’s installed in the car and you will need to remove the bezel before you try to replace the button.
If you remove the retainer from the old button it will usually break off the plastic stud made on the end of the button. Once this is done, you will need to remove the old button and install a new one. The button goes in first, then the spring and then the retainer.
This instruction sheet is for the dash pads, but if you skip to page three you will see the center dash bezel instructiosn start.
http://willcoxcorvette.com/repairand...lp.php?hID=105
Willcox Inc.
