Gas Tank ??????
Old Apr 10, 2008 | 09:55 AM
DL9179's Avatar
DL9179
Default Gas Tank ??????
How many gallons of fuel does a 77 vette hold ?
Old Apr 10, 2008 | 10:09 AM
7T1vette's Avatar
7T1vette
The standard C3 tank can hold around 14 gal (or a little less). From a normal use situation, you will probably be getting fill-ups of 10-12 gallons [otherwise running on 'empty']. In city driving, thats a fill-up every 150-180 miles.
Old Apr 10, 2008 | 10:18 AM
DL9179's Avatar
DL9179
So then when my gauage says E it should take about 10 gal. to fill it up ?
Old Apr 10, 2008 | 11:27 AM
rosslato's Avatar
rosslato
i just bought a new stock tank for my 73 n it took exactly 17gallons to fill
Old Apr 10, 2008 | 11:28 AM
Durango_Boy's Avatar
Durango_Boy
The rubber bladder in the tank may have failed, and is collapsing in on the inside of tank, either giving you false level readings, or limiting how much fuel you can put in.
Old Apr 10, 2008 | 11:29 AM
rosslato's Avatar
rosslato
bout 15
Old Apr 10, 2008 | 11:31 AM
rosslato's Avatar
rosslato
when u goto buy a new tank all the vendors claim approx 25 gallons but in reality they're 17gals as mine was exactly the same as my stock tank which held 17gals
Old Apr 10, 2008 | 11:32 AM
Darrel1's Avatar
Darrel1
Not sure if the 1980s are different but I think my tank holds just shy of 24 gallons!! From what I can remember from filling up last fall
Darrel1
Old Apr 10, 2008 | 11:35 AM
blckslvr79's Avatar
blckslvr79
I read somewhere that pre-78 cars where 17 gallon and 78 and later cars where 25 gallon.
Old Apr 10, 2008 | 02:22 PM
DL9179's Avatar
DL9179
Wow ! Im realy off then either my gauage is way off or its like DURANGO said my sock has colapsed because when it says e it takes right at 10 gal to it stops pumping
Old Apr 10, 2008 | 02:24 PM
DL9179's Avatar
DL9179
Is there anything i have to worry about besides less fill ups ?
Old Apr 10, 2008 | 02:50 PM
Durango_Boy
It's possible that the bladder might hinder the pickup, and block the flow of fuel, but for the most part it's a capacity thing.
Mine was in rough shape, so i removed the bladder, and actually got about another full gallon of space. I now have a 16 gallon tank.
Old Apr 10, 2008 | 03:13 PM
DL9179's Avatar
DL9179
Ok thanks , i guess ill live with it for now or untill i can aford to fill it up lol
Old Apr 10, 2008 | 03:57 PM
GD70's Avatar
GD70
The owners manual for my 70 says 18 or 20. I think it was 18 when I filled it from bone dry.
To Gas Tank ??????
