Side Pipes
Old Apr 15, 2008 | 08:31 PM
ERACERX's Avatar
ERACERX
Default Side Pipes
I'm a C5-6 guy looking at a C3 and was wondering about side pipes. I have heard horror stories about the heat but would appreciate any positive or negative feedback.
Thanks!
Old Apr 15, 2008 | 08:41 PM
Durango_Boy's Avatar
Durango_Boy
Welcome to the C3 section...hope to see you driving a C3 soon.
The heat can be battled. Removing the carpet, and laying down a layer of a product called Reflectix, will greatly reduce the heat absorbed into the cabin. You can also make shields that screw onto the underside of the cabin, covering the foot wells from the exhaust.
I have a '77 with side pipes and after a few hours of driving the heat has soaked into the cabin and does get hot. I layed down some sound deadening material and jute under the carpet to help guard against heat.
Old Apr 15, 2008 | 08:48 PM
Glassbowtie77's Avatar
Glassbowtie77
Pros: The look great and sound awesome depending on the inserts you use.
Cons: You and your passenger just have to be careful getting out unless you want the C3 tattoo.
Old Apr 15, 2008 | 08:58 PM
ShinodaVette's Avatar
ShinodaVette
Thanks!
I had always heard that the side pipes helped remove some of the heat from the interior by getting the exhaust out from under the car. I got my side pipes Jet Hot coated but my C3 isn't anywhere near drivable yet.
Old Apr 15, 2008 | 09:14 PM
Yankees031's Avatar
Yankees031
St. Jude Donor '08
You can combat this by getting Jet-hot coated ones. I have them an they never even get hot enough where they can't be touched.
Old Apr 15, 2008 | 10:14 PM
Shoevette's Avatar
Shoevette
I have zero problem with heat in the cabin. BUT -- wear shorts and forget to step over on the way out........
Worth it.........
Old Apr 15, 2008 | 10:26 PM
'Bochawa72's Avatar
'Bochawa72
I have the Jet-Hot coated hookers on my 72 and they will definately burn you getting out if you're not careful. However, the cabin temps are MUCH cooler than when I had the stock exhaust in place.
-CR
Old Apr 15, 2008 | 10:56 PM
Doug70vert's Avatar
Doug70vert
From: Part breakage is just weakness leaving my Stingray
I can't say that I've ever noticed a significant difference in the heat in the interior. However, the pipes and especially the header tubes are super hot. You'll learn a new way to get in and out of your vette or else...
As for the upside. It's hard to beat the sound especially with JCL sprial baffles. They also make the car look very cool. Of course I'm biased, but who on this site isn't.
Old Apr 15, 2008 | 11:06 PM
Yankees031's Avatar
Yankees031
St. Jude Donor '08
-CR
Thats strange because I can literally leave my hand on mine for as long as I want...they just dont get that hot
Old Apr 16, 2008 | 03:33 PM
ERACERX's Avatar
ERACERX
Thanks for the feedback!
Old Apr 16, 2008 | 04:00 PM
Triple Black 68 Vert's Avatar
Ditto.
C3'3 were made for sidepipes. Hooker and Jet Hot is the way to go!
Old Apr 16, 2008 | 04:23 PM
Glensgages's Avatar
Glensgages
Originally Posted by Triple Black 68 Vert
..... Hooker and Jet Hot is the way to go!
..... gotta a question about Hooker headers & sidepipes that are ceramic-coated:
lota guys talk about Jet-Hot'd Hookers, but are the sets you buy, like this,
http://store.summitracing.com/partde...5&autoview=sku
Jet-Hot'd (brand), or is this a Hooker-applied ceramic coating, LIKE Jet-Hot (and is there a difference between Jet-Hot brand and manufacturer-applid coatings, and if-so, which is better) ?
I had headers for my dragster ceramic-coated by Jet-Hot in '94, and although I no-longer own the car, they still look perfect.
Thanks-in-advance!
Old Apr 16, 2008 | 09:16 PM
rosslato's Avatar
rosslato
-CR
got the same jehot coated headers n they will burn the snot outta of yer flesh if u let em.
Old Apr 16, 2008 | 09:20 PM
rosslato's Avatar
rosslato
Thanks-in-advance!
the sets u buy at jet hot are the same BUT summits ceramic headers are prone to rust within a year cuz they don't coat the inside. just buy them direct from jethot plus jethot has better prices than summit and the warrantee
To Side Pipes
