How you doing Will, glad to see you're making good progress, would like to see it sometime!
I am doing fine. Anytime you would like to see it come on over. I bought a piece of land near you on craig creek, 11 miles up the creek from Eagle Rock and a lot of my time has been spent there. Working and relaxing now that spring is here I will be spending more time there.
Tahnks for the comments and incouragment from everyone. It has been over 4 years now since starting this and I am finaly seeing some light at the end of the tunnel. The paint has some flaws but this is the first car I have ever done and I'am still learning after this I get to start on a 64 chevy2 with my little girl. After that I should know if I like steel or fiberglass.
Are you wetsanding and buffing, or just buffing? Love the color!!
Wet sanding and buffing.
Hopefully the sanding is done , I have sanded on this thing so much I hate to think about it. First was stripping the paint, then I shoot several coats of gelcoat on it and had to sand the orange peel out between coats, then it was primer time same story more sanding and last it was sanding the first clear coat and reshooting and then more sanding.
