Diff Fluid
Old Apr 23, 2008 | 06:31 AM
guitarcrazy02's Avatar
guitarcrazy02
Default Diff Fluid
Got a whine coming from the rear end. Nothing bad, just barely noticable.
Going to change the rear end fluid this weekend.
Just curious as to how often everyone changes theirs. I'd bet that mine's original.
Old Apr 23, 2008 | 07:38 AM
worship79's Avatar
worship79
Changed mine because it started 'clunking' at slow speeds: it was definately original (black and stinky). Don't know official mileage between changes.
Old Apr 23, 2008 | 09:15 AM
DIPPOLD's Avatar
DIPPOLD
Strange, I just changed mine last Friday in 20 years. It wasn't in bad shape didn't hear any strange noises etc. Switched to Royal Purple full synthetic. I only put about 3K miles on it a year.
Old Apr 23, 2008 | 10:30 AM
srosa75's Avatar
srosa75
I'm starting to get a whine too. Let us know if that helps.
Old Apr 24, 2008 | 06:31 AM
guitarcrazy02
I'm sure hoping that it fixes it. That's the one area of the car that I've neglected to address, so I'm sure it needs something. I really don't feeling like shelling out almost a grand for a new diff or to get mine rebuilt. We'll see what happens.
Old Apr 24, 2008 | 08:25 AM
Don Rickles's Avatar
Don Rickles
2017 C3 of Year
Same here, had some noise coming from the rear. It's amazing what a little fluid can do. Try to remove all of the old fluid, I used a small hand pump. After filling the diff. take the car to an open parking lot and do several figure 8's at slow speed, this will bring the fluid up into the gears. Also don't forget to add the whale oil, or the newer synthetic additive! Good luck WB
Old Apr 25, 2008 | 01:04 PM
bgall2's Avatar
bgall2
Default Don't forget special flui
I just chanced my diff fluid and it made a world of difference in the sound of the rear end. my 78 calls for a 4 OZ tube of special fluid that goes in the diff with the change. look at the specs and see if yours requires this. DON"T forget it as I think this is what makes the big difference. Then just fill with 80-90 diff fluid. I have no drain fluid and had to suction mine out...worked well.
Old Apr 25, 2008 | 04:30 PM
7T1vette's Avatar
7T1vette
You may not have as much fluid in there as you expect....if it hasn't been changed/topped-off in 35 years. There is NO drain plug..only a fill plug. You have to syphon or suction out as much of the old fluid as you can (turkey baster with a length of hose, etc.). Then refill with GM differential gear lube and some posi-trac fluid. Put in half of the gear lube, then the posi-lube...then fill rest with gear lube until it starts to run out of the fill hole. Plug it up and go.
Old Apr 25, 2008 | 09:04 PM
Carl Granquist's Avatar
Carl Granquist
7T1vette: you make it sound simple. Archive search has one member using "Lucas 85-140 gear oil & GM posi additive." Would you recommend something else?
I agree with you that a change or topping off might be in order. Is it a short one-hour garage session plus a short test drive? Something I should probably do before summer.
Old Apr 26, 2008 | 03:09 AM
7T1vette's Avatar
7T1vette
Once you have the new lube, posi additive and a way to suction out the old stuff, the job is a "piece of cake". You do need a square drive adapter for your ratchet to remove the plug; I think it's a 1/4" or 3/8" square recess in the plug. You can put some thread sealer on the plug when you reinstall, if you want; but don't overtorque it or you can crack the housing.
Old Apr 26, 2008 | 09:18 AM
jim2527's Avatar
jim2527
Easy job. I used a big crescent wrench to get the plug out.
Old May 5, 2008 | 08:48 AM
DIPPOLD's Avatar
DIPPOLD
I put in Royal Purple, do I need to add the positract fluid with this stuff?
Old May 5, 2008 | 10:22 AM
GD70's Avatar
GD70
I've got a whine as well, but when I let off the gas it goes away, give it gas it's back. I also notice it seems to go away when cornering at speed. Don't have any clunking sounds. Think it's also just a fluid change I need?
Old May 5, 2008 | 10:42 AM
pws69's Avatar
pws69
Nope! Probably a bearing or incorrect lash. How long has it been doing it?
Old May 5, 2008 | 10:44 AM
SharkintheWoods's Avatar
SharkintheWoods
I bought the Royal Purple as well. It had the posi additive in it already, but I am waiting as well on everybody's opinion whether this is enough.
Old May 5, 2008 | 11:12 AM
GD70's Avatar
GD70
I've had it a year and a half and it's made the sound since I bought it. A friend of mine has a 69 and when he drove it and I asked about it he said it was a normal sound and to be worried if it wined while coasting, not while giving it gas.
If a bearing is the problem, one of the side bearings I would assume?
Old May 5, 2008 | 12:30 PM
C3 RV's Avatar
C3 RV
St. Jude Donor '15
I put Schaeffer's 267 Gear Lube in to quiet my diff. It helped.
http://www.schaefferoil.com/gear_oils/267.html
To Diff Fluid
