Where exactly is the axle code
Old Apr 23, 2008 | 03:23 PM
DZRick's Avatar
DZRick
Default Where exactly is the axle code
Using the lamp as a reference point where am I supposed to find the axle code?
My battery died or I would've taken a shot of the other side too.
I found the build date but I can't find the axle code.
Old Apr 23, 2008 | 03:48 PM
AirTrafficController's Avatar
I believe the build date is on the same line as the axle code. It should be a 3-letter code. Mine was extremely hard to read, but I managed to make it out:
Mine says
2 CAO 12 17 69 =
2 =2nd shift
CAO =3.70 rear
12 =Dec
17 =17
69 =1969
halfmoontrail's Avatar
halfmoontrail
stamped on the bottom, not very deep or distinct.
Steve
Old Apr 23, 2008 | 03:49 PM
lakebumm's Avatar
lakebumm
2022 C2 of the Year Finalist - Modified
RICK,
I FOUND THE REAR END CODE ON MY '66 STAMPED ON THE BOTTOM OF THE MAIN CASE JUST IN FRONT OF THE REAR COVER. IN OTHER WORDS, IN YOUR PICTURE YOU SEE THE TWO REAR COVER BOLTS AT THE TOP OF THE PICTURE. MY CODE WAS STAMPED IN THE AREA BETWEEN THOSE TWO BOLTS, BUT ON THE CASE, NOT ON THE REAR COVER. (between where the strut bracket mounts and the rear cover)
HOPE THIS HELPS. LET US KNOW.
BILL SR
Old Apr 23, 2008 | 04:32 PM
DZRick's Avatar
DZRick
Thanks guys but I think my numbers are gone for good.
Old Apr 23, 2008 | 11:38 PM
427-390's Avatar
427-390
One day while I was under the car, I went to look for the axle code. I couldn't find my rear axle code where it should have been, or so I thought.... Just for the heck of it, I cleaned the entire underside of the diff with some degreaser, and to my astonishment, I was able to read the code. If you haven't done this, try it. The stamping is very faint, so make sure you have good lighting when you look. Good luck
Old Apr 24, 2008 | 12:06 AM
DZRick's Avatar
DZRick
Thanks, I'll give it a try.
With this being stripped down ie. no drive or half shafts is there any way to calculate the ratio.
To Where exactly is the axle code
