New Starter left me stranded!
Old Apr 23, 2008 | 04:10 PM
IrishJoker's Avatar
IrishJoker
Default New Starter left me stranded!
Had to replace my starter so I got a genuine Delco starter. It apparently over-heats and the solenoid sticks until it cools down. I normally do not carry a hammer with me - otherwise I would have hit that sucker to free it up. I had to sit for 45 minutes waiting for it to cool down. Now I carry a hammer.
My question is -
a: Order a heat shield from Summit.
b: Turn this puppy in and order a new mini starter from Summit.
c: Turn this puppy in and order a new Stock starter from Summit.
The start has a lifetime warranty which I am sure is pro-rated but I should get most of my money back. I installed last fall and didn't have a chance to drive much afterwards. The lock-out only seems to happen after I've driven for about an hour and the heat builds up - short trips seem ok.
Old Apr 24, 2008 | 11:52 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Like every other thread on the subject says - buy the mini Delco starter from later-model SBCs. Little gear-reduction thingy that resembles a half-sized stock starter. Works like a charm.
Old Apr 25, 2008 | 08:19 AM
Ironcross's Avatar
Ironcross
Sams advice above is the best you can get.
However check your battery voltage when this happens with a good volt meter before and after it starts. You just may not be placing a adequate charge back into the battery and is slowly running the charge out. Or, better yet go to a service center or parts store that has a 'Sun' machine {Vat 28} or equivalent that can check both your cranking and charging systems.
Old Apr 25, 2008 | 11:16 AM
IrishJoker's Avatar
IrishJoker
Nope voltage isn't an issue - checked the voltage on the battery and my volt meter on the dash works just fine - the battery is getting plenty of juice, it's simply over-heating on a regular basis.
Old Apr 25, 2008 | 01:23 PM
pbcanney's Avatar
pbcanney
If it doesnt disengage that usually means it needs to be shimmed. All my research material is packed so I cant tell you if it should be shimmed inside or outside but someone here should know. (or there should have been shimming instructions with your starter differenciating between wont engage / wont disengage)
Old Apr 25, 2008 | 01:35 PM
danthony's Avatar
danthony
2024 C3 of the Year Finalist - Unmodified
Did you put the factory heat shield on? Those often go missing over hte years
Old Apr 25, 2008 | 01:37 PM
moosie982's Avatar
moosie982
If price is no matter I'd go with the mini, and any kind of heat shield and dont be using that hammer too much or you could run into issues about the guarantee on the new not working properly one. Good Luck, Peace,,, Moosie
Old Apr 25, 2008 | 04:25 PM
7T1vette's Avatar
7T1vette
Call the place where you bought the Delco starter and tell them your problem and that you want your money back. They will probably offer you a swap to whatever you want. Your warranty may not 'allow' a refund of money....maybe only an amount that you can exchange for something else they sell. Good luck.
Old Apr 25, 2008 | 06:02 PM
Ironcross's Avatar
Ironcross
Sounds good, great thinking. Good idea.. Except most places have checking equipment. So it`s checked and declaired as nothing wrong. Electrical parts are not refundable. And a starter is an electrical part. Now what? This poor guy has crawled under his car at least twice for nothing and has to go back again. Now if he would have had his first one checked either on the car or off he wouldn`t have the starter problem any more and the car repaired with what he actually needs. Starters are normally sold exchange so his original is now probably considered gone and He may have bought a starter for nothing...
Old Apr 25, 2008 | 06:53 PM
alanbl's Avatar
alanbl
I'd be glad to sell you the hammer I used to carry in my MGB, but it was for the fuel pump, not the starter. Might not be the right part.
Old Apr 25, 2008 | 08:14 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
The washer motor in my '65 Mustang needed to be clobbered every once in a while or it would just stop doing anything.
Old Apr 25, 2008 | 08:45 PM
7T1vette's Avatar
7T1vette
Ironcross...
The guy said the starter had a "lifetime warranty" and he said nothing about taking it back already. Not sure what thread you're on...
Old Apr 25, 2008 | 10:15 PM
Ironcross's Avatar
Ironcross
Ironcross...
Your right he didn`t, you did.
Old Apr 25, 2008 | 10:18 PM
milo30's Avatar
milo30
Don't need a hammer or a new started. Just carry a cooler of iced down beers for the wait.
Old Apr 25, 2008 | 10:44 PM
Fuelie74's Avatar
Fuelie74
Check your wire routing. If the S terminal wire is to close to the exhaust it will give you that problem because as the wire gets hotter its resistance goes up and the voltage to the solenoid goes down.
Old Apr 26, 2008 | 01:18 AM
rihwoods's Avatar
rihwoods
Sometimes it's just a weak solenoid spring....had this same issue on my 78 years ago....replaced solenoid spring,and the sucker still works today....Delco...of course...
Rich
To New Starter left me stranded!
