Tig Weld Question
Old Apr 24, 2008 | 08:03 PM
Ta-taaa's Avatar
Ta-taaa
Default Tig Weld Question
Can the metal that the head light cover be Tig Welded?
Old Apr 24, 2008 | 08:09 PM
V-Twin's Avatar
V-Twin
Yes
Old Apr 24, 2008 | 08:10 PM
Maymyvetteliveforevr's Avatar
Are we talking about the chrome plated trim that surrounds the headlight to keep it in place?
Yes it can be Tig Welded but what part needs to be welded and is the chrome plating still on? Are you concerned about the cosmetics? Do you have any pictures.
Old Apr 24, 2008 | 09:00 PM
Ta-taaa's Avatar
Ta-taaa
no.... one of the arms broke off..
Old Apr 24, 2008 | 10:13 PM
jds68stang's Avatar
jds68stang
Ask the TIG welder about possibly using silicon bronze, may not need as much heat.
Old Apr 25, 2008 | 09:41 AM
If you're not to concerned about the cosmetics then ask the welder to use the smallest Tungsten they have and a fairly low melting point rod as jds68stang suggested. But then again, the welder will know this. Another method which would give good results is to spot weld it. I believe that's how it was done at factory if I remember correctly.
Old Apr 25, 2008 | 11:54 AM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
I had a pair welded in Fort Worth and they turned out great. He used his Mig to weld it. I assume you are talking about the u-shaped bracket that holds up the whole assembly.
Old Apr 25, 2008 | 12:12 PM
I thought he was talking about the chrome trim around the headlight, my bad!
Old Apr 25, 2008 | 03:45 PM
stpman's Avatar
stpman
What did they use (wire & gas) I have a couple I would like to save
Steve
Old Apr 25, 2008 | 07:47 PM
67-73-76's Avatar
67-73-76
I think those rims holding the headlights in are stainless.
Old Apr 25, 2008 | 09:32 PM
Ta-taaa's Avatar
Ta-taaa
One of the "arms" Snapped in half when I was trying to raise it. It broke just above where it hinges.
Old May 1, 2008 | 09:43 AM
I may be getting a bit off topic since the OP may have been talking about a different trim. Either way if the trim we're talking about is stainless then a tig or spot welder would be perfect for the job.
Anyone know if the trim to hold the headlights in place are stainless?
Old May 1, 2008 | 12:05 PM
V-Twin's Avatar
V-Twin
He broke the actual lamp cover. It's aluminium and can be welded
To Tig Weld Question
