Explain the gauge...
Old Apr 26, 2008 | 02:42 AM
jerrylee's Avatar
jerrylee
Default Explain the gauge...
Can you guys educate me as to what is the differance between an electric and mechanical gauge also the differance between short and full sweep...Thanx....Jerrylee///
Old Apr 26, 2008 | 05:38 AM
tigers123's Avatar
tigers123
Default gauges 101
Electrical gauges have a sending unit, wire between, and the gauge itself is electrical. Electrical resistance in the sending unit is measured by the gauge on the dash. Examples of electrical gauges are fuel, water temp, oil pressure, clock, tachometer, speedometer and ammeter or voltage gauge. They all can be electric. Speedometer, Tachometer. vacuum gauge, oil pressure, and water temperature can also be found to be mechanical. The gauge is acted upon to move the needle by mechanical force or pressure. Example if the water temperature gauge is mechanical heat from the water in the block expands alcohol in a capillary tube to expand that is attached to the dash gauge causing the needle to move. The "sweep" on the gauge refers to the distance the needle on the gauge face travels usually in an arc. The full sweep moves the needle around similar to the hands on a watch face. Almost full travel on the dial. Most generally electrical guages are preferred to mechanical because their ease of installation and less chance of breaking any tubes or lines. A good example of a common mechanical guage still in use in a lot of cars is the speedometer. But a lot of the newer cars are going electrical on the speedometer as well.
Old Apr 26, 2008 | 10:31 AM
pbcanney's Avatar
pbcanney
full sweep fuel
________________________________________ _____
short sweep fuel
Old Apr 26, 2008 | 01:10 PM
jerrylee's Avatar
jerrylee
Default Gauges...
Thanx 4 the quick lesson guys...Jerrylee///
To Explain the gauge...
