Hard top for a '72 vert?
Old May 3, 2008 | 12:15 PM
Casper's Avatar
Casper
Default Hard top for a '72 vert?
What's a good hard top for a '72 vert worth? Some guy told me he had one and doesn't need it any more. I ask what he wanted and he said he didn't know. He gave me his phone and address and told me to come by and check it out. What should I offer? I have no idea.
Old May 3, 2008 | 12:32 PM
Chris Farrer's Avatar
Chris Farrer
600 - 800 in good condition sounds about right.
Old May 3, 2008 | 12:50 PM
jim2527's Avatar
jim2527
$600 if its the wrong color.
upto $1000 if its the right color.....
Old May 3, 2008 | 01:37 PM
PRNDL's Avatar
PRNDL
Headliner, glass, and hardware are expensive components, so if these are in decent shape it is hard to find a top for <$500. If you are going to look at it, drive over in your vette. Easiest way to bring it home is on your vette.
Old May 3, 2008 | 01:44 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
I think the range above is about right: $600 to $1000. Start deducting if the headliner is missing/bad (~$400 to replace), weatherstrip (most that I've seen are bad. ~$250 to replace) and worst of all, the back glass. If you can find a glass, it'll really cost you. Most of the replacements are plastic which, in my opinion anyways, almost defeats the purpose of a hardtop; good visibility.
Although not as expensive as repainting, if it is a vinyl covered top, check the vinyl over. Replacement isn't all that expensive, but not that easy of a job.
Old May 3, 2008 | 09:44 PM
milo30's Avatar
milo30
Hardtops aren't expensive because most people don't want them after they have themm because they take up so much space. I got mine in great shape for $500.
Old May 4, 2008 | 08:32 PM
tmacb's Avatar
tmacb
I've done a great deal of searching for tops for my 71. My experience over the past year or so has been pretty close to the numbers that others have posted here ($400-$1000 for the bulk). I have run across a few crazies that wanted as much as $2000-$2500, and although for very nice tops, this seems way out of line for something that was produced in relatively high numbers. If you are looking for a perfect, original top that matches the numbers on your car for perhaps NCRS judging, than perhaps I could see these numbers becoming more realistic. Otherwise it's ridiculous. The biggest problem I have run into is finding a top close eneough to drive to. Most sellers are not willing to ship and shipping costs as much as a top in many cases anyway. If anyone out there has or knows of a top in the Pacific Northwest, I'm looking.
As others have mentioned, things like glass and trim make a big difference. The trim that runs around the front section of the top can be very difficult to find and many tops have dings in those areas. Front corners for instance are very suceptible to damage. Most other parts are available pretty readily in the aftermarket.
Old May 4, 2008 | 09:49 PM
milo30's Avatar
milo30
I think that the shipping issue is a big part of what makes the prices so low. My advice is to watch ebay. I found mine there in perfect condition. I had to drive about 4 hours to get it and when I got home I found one 10 minutes way for the same price. It's hard for them to get bids when it's a local pick up.
Old May 5, 2008 | 12:55 AM
Chris Farrer
My '72 had a hard top that came with the car when I bought it.
Don't believe it was original to the car because the rear glass is dated '69, however I have one and it fits very well.
The only time I had it on was when the car was shipped out to Australia and then when I took it to an NCRS meet in Melbourne.
I did find even though all care was taken uncluding putting a clear plastic strip under the weather strip it still left an indentation in the paint on the rear deck lid.
Have seen many convertibles and this seems to be a common problem. It doesn't matter how soft or hard the top is fitted there is always going to be flexing/movement and this will mark/indent the paint.
Old May 5, 2008 | 04:38 AM
RHD '68 L89's Avatar
RHD '68 L89
Chris,
I have used a strip of Paint Protection Film on my decklid for several years now. The PPF is stuck to the decklid where the Clear plastic (Cleartastic?) uses static cling to hold it in place. It is the moving around which causes the marks/erosion in the paint.
The weatherstrip on the soft top is trying to eat into the film but it is getting nowhere
To Hard top for a '72 vert?
