Emblems
Old May 5, 2008 | 05:31 PM
Jaybird907's Avatar
Jaybird907
Default Emblems
I have seen a thread on here before where someone restored there emblems. I looked for the thread but can't find it. Can anyone who has done it give me some pointers?
Old May 5, 2008 | 05:41 PM
Durango_Boy's Avatar
Durango_Boy
I soaked mine in a bowl of Aircraft remover. I then rinsed them or all the paint and chemical, and let them dry. Then, I used a few tooth picks and some Testers paint to re-paint them.
Cost a few bucks at any hobby store and I really like the way they turned out.
Before:
During:
After:
Old May 5, 2008 | 05:43 PM
Jaybird907's Avatar
Jaybird907
I thought that it was you that had done it before. You beat me to it, I was just getting ready to PM you about it. Thanks!
Old May 5, 2008 | 10:54 PM
Theiskell's Avatar
Theiskell
[QUOTE=Durango_boy;1565324663]I soaked mine in a bowl of Aircraft remover. I then rinsed them or all the paint and chemical, and let them dry. Then, I used a few tooth picks and some Testers paint to re-paint them.
DB,
I was given about 5 old emblems and would like to try this on them. When you said testers are you talking about spray paint or does it come in a bottle? I remember testers for model cars but cant seem to remember how it came.
Old May 5, 2008 | 11:26 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Testors is sold both as a spray and bottled paint.
Old May 6, 2008 | 07:46 AM
Durango_Boy
DB,
I used the bottle Testers, as it's a lot easier to control, and you won't have to tape off such painfully small areas.
Old May 6, 2008 | 07:59 AM
Jaybird907's Avatar
Jaybird907
You said that you picked up the paint from a hobby shop? I'm sure a bottle of touch up paint would work too? Yours turned out great!
Old May 6, 2008 | 08:29 AM
Saint's Shark's Avatar
Saint's Shark
Great job Durango Boy - they look good. What is Aircraft remover? Where could I get some of this stuff?
Old May 6, 2008 | 09:03 AM
Durango_Boy
Aircraft remover is a chemical paint stripper. It's fully water soluble, so it cleans up with plain tap water in no time.
I got mine at a local Autozone, so I suspect it can be found at most parts stores.
It's cheap, and easy to use. Just read the directions, and that's all there is to it.
Old May 6, 2008 | 11:04 AM
Dantana's Avatar
Dantana
That really looks good DB! - - and seems relatively simple to complete. I'd like to do my front emblem if I could get it off there to strip it... any ideas anyone? I assume it is glued on...
Old May 6, 2008 | 05:55 PM
gbags's Avatar
gbags
I stripped with fingernail polish remover and a toothbrush. Worked great.
Small bottles of testor paint and toothpicks did the trick.
Old May 6, 2008 | 06:10 PM
Alan 71's Avatar
Alan 71
It's one of the few things that's actually pretty easy to do AND get good results AND save a few $$.
Regards,
Alan
Old May 6, 2008 | 06:11 PM
427basketcase's Avatar
427basketcase
I also used Testors® but found the red a little too bright, so I dabbed a little black into the red, (mixed seperatly) came out near perfect
Old May 6, 2008 | 07:09 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
They make many shades of red - IMHO, their Dark Red is a much better match for the original emblem color.
Old May 7, 2008 | 08:26 AM
Trae1976's Avatar
Trae1976
For you guys that have gone the hobby paint route, how has it stood up to weather and UV?
That would be my only reservation about using it, as its intended usages see much milder conditions.
Old May 7, 2008 | 10:02 AM
Wuttin's Avatar
Wuttin
Before and after; same basic treatment, strip and repaint with modeling paint, although I think I used Tamiya which flows really nicely. I used one of the diamond hard water-based clear coats after painting and it's holding up great. It sees some weather since my car lives in the driveway under a car cover which does let moisture through.
Old May 7, 2008 | 10:27 AM
70Yellowbird's Avatar
70Yellowbird
The credit for this should go to 7T1vette ... so PM him if you want more detail ... he used Pebeo Porcelaine paint purchased at Michael's stores ... Anthracite Black, White, and Scarlet Red ... after applying paint, it's baked on in your oven, so it may be more durable.
I have wanted to repaint my emblems for a long time ... but still need a few questions answered ... mostly having to do with the many shades of red.
So I don't steal this thread, I'll start another on that topic.
To Emblems
Old May 7, 2008 | 10:48 AM
Ron R's Avatar
Ron R
You know I was just thinking that on a black car, the unpainted look would be pretty freakin cool. Just polish it up, shoot a clear coat on it and mount it.
Old May 7, 2008 | 12:31 PM
candacedianne's Avatar
candacedianne
YOu can purchase new ones through the Last Detail and MidAmerica. Good luck!!
Old May 7, 2008 | 05:33 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Why bother if the chrome is still good? Paint is a lot cheaper than new emblems.
