C3 vs C4 Suspension
Old May 6, 2008 | 02:22 AM
Hodos's Avatar
Hodos
Default C3 vs C4 Suspension
Can someone tell me what I have here? I'm thinking it's a C3 rear end with the wrong differential cover. I know little other than it's supposedly out of an '85. It's obviously not a c4 rear, but would the differences be (width, brakes, weight, etc...)?! I apologize for the lousy pics, but it is night time... Ultimately, I would like to put this into my 1950 GMC, but I think I would rather have a newer/lighter version.
Thanks in advance!
Old May 6, 2008 | 07:30 AM
gator79's Avatar
gator79
with those trailing arms it has to be a a C3 probably an 80 or 81
Old May 6, 2008 | 07:34 AM
78Vette-SA's Avatar
78Vette-SA
Looksd like an 80-82 Dana 36. If you are going to put any power in that truck, I would suggest getting a used Dana 44 if you are looking for a beefier IRS. They are not cheap though. I've seen good used ones go for $1500-2500 depending on condition and what's included. Many come with 3:45 gears but are easily changed if needed (before you put it in the truck of course).
Old May 6, 2008 | 09:54 AM
Hodos's Avatar
Hodos
I thought it was a Dana 44. It seems to have the correct bolt pattern. The top brace has me confused, but was that the way they were in 80-82?
http://temp.corvetteforum.net/c4/mrmojo2//danarear.jpg
Old May 6, 2008 | 11:14 AM
7T1vette's Avatar
7T1vette
Definitely not a C4....aluminum doesn't 'rust'.
Old May 6, 2008 | 02:21 PM
Hodos's Avatar
Hodos
Alright, so my best guess on this is a C3 Dana 44 rear with a C4 dif cover. So, if I were looking for replacement parts, I would look in the C3 section. Thanks guys.
Old May 6, 2008 | 03:19 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
My guess: 80 stock rear. Fiberglass rear springs for the 81 and 82 models unless you went with the FE7 option in '81. Calipers are C3 and not C4.
Old May 15, 2008 | 01:36 AM
Hodos's Avatar
Hodos
So after doing some digging around, it looks like you guys were pretty much spot on with this rear. From what I've found it's a 1980 Rear due to the 9 leaf metal leaf spring (2 1/2" width) and the mount is triangular instead of the dogbone looking piece. Now, my only question would be is it for an auto or manual. It has 12 pt bolts holding in the u-joints, is this a clear indication of a manual? I would like to order all new u-joints and there seems to be a difference between the two different trannys.
Thanks again!
Old May 15, 2008 | 05:20 AM
V-Twin's Avatar
V-Twin
it's an 80 or 81 (it's not an 82 most likely as it has a steel leaf spring and all 82s w/ FE7 had aluminium strut rods)
It's also a C3 batwing, the diff is a Dana 44, there's no such thing as a C3 D36.
Old May 15, 2008 | 11:27 AM
SharkintheWoods's Avatar
SharkintheWoods
My 80 has twelve point bolts on the half shafts and it is an auto. Not sure what the telltale signs between auto and manual for this.
Old May 15, 2008 | 11:44 AM
V-Twin's Avatar
V-Twin
They are inverted torx, all 80-82s have those. The only difference is that 80&81 manuals an all 82s use the 3" shafts, 1350 u joints and 7/16 bolts. The others use smaller equipment.
Old May 16, 2008 | 06:46 AM
Hodos's Avatar
Hodos
Many thanks to V-twin (and really to everyone who's replied). I'm slowly getting all this info sorted out. Hopefully by the end of rebuilding it, I can consider myself "knowledgeable". I was confused by those bolts, just figured they were 12 point. They are slightly rusted and should probably be replaced as well. Fun, fun fun...
To C3 vs C4 Suspension
