Exhaust Manifold Paint
Old May 7, 2008 | 09:01 PM
GR8DAIN's Avatar
GR8DAIN
Default Exhaust Manifold Paint
I'm about to repaint my exhaust manifold. I got some MG-69 manifold dressing.
Do I need to sandblast the manifolds first? Is that even possible? - It is a special paint I guess. The exisitng paint is not that bad but could be better... What about coating?
Please advice, thanks.
Old May 7, 2008 | 10:10 PM
roger55's Avatar
roger55
I like Calyx.
You do have to do touch up once in a while but it is easy to do.
Old May 8, 2008 | 10:09 PM
dobroman2001's Avatar
dobroman2001
I just used Calyx on my Manifolds. PO had painted the Manifolds with some type of high temp paint. I tried to brush off the loose paint flakes with a small wire brush while they were still on the car. I got some of it off but not all..... sent an email to Calyx and ask if it was OK to apply their dressing over the paint. No reply from them. I just went ahead with the application, they look AWESOME!!!
Old May 8, 2008 | 10:32 PM
Mia's Avatar
Mia
Ok, this answers my questions on the Calyx. Just saw it in the Eklers catalog tonight and was curious as well. Can this be found locally, at say an auto parts store, or only via catalog?
Old May 8, 2008 | 10:40 PM
roger55's Avatar
roger55
I've never seen it for sale at a local retailer.
Old May 8, 2008 | 10:50 PM
C7GrandSport's Avatar
C7GrandSport
It works great. Just get it from Ecklers or whoever. Apply it with a toothbrush.
Old May 8, 2008 | 11:04 PM
Mia's Avatar
Mia
The caption in the catalog seems to indicate you can apply it with the headers installed?
Old May 8, 2008 | 11:10 PM
dobroman2001
Yeah, I've haven't seen it sold anywhere other than Corvette parts vendors or Summitt...etc. As for the application, I put latex gloves on and used my fingers to rub the dressing on..
Old May 9, 2008 | 12:32 AM
C7GrandSport
Yes.
Old May 9, 2008 | 05:55 AM
BarryK's Avatar
BarryK
Calyx never completely dries and will rub off on anything that touches it.
I prefer a painted solution rather than a "dressing" for that reason.
Here are the manifolds I did off my '78 with Eastwoods Factory Gray hi-temp manifold paint.
You can get in in a spray can or small can to brush on. I brush it on.
The manifolds themselves I did with the Factory Gray than did the A.I.R. tubes with basic black.
did these 2 years ago and they still look the same today
Old May 9, 2008 | 11:01 AM
7T1vette's Avatar
7T1vette
Calyx is good stuff...particularly for the person who doesn't want to remove the manifolds from the engine. If yours are already out, you can clean them up much better and apply a more permanent coating. I use Calyx and it does look like fresh cast-iron; but I have to touch it up every now and then. A good high-temp coating might be preferable....it's really up to what you want for your car.
Old May 9, 2008 | 11:11 AM
Mia's Avatar
Mia
Anyone have pics of Calyx'd manifolds?
Old May 9, 2008 | 12:21 PM
7T1vette's Avatar
7T1vette
They look about the same as the painted ones shown above...at least, right after you do them. They'll stay that way for some time, but areas will eventually flake off and you'll need to touch them up. Still, a pretty good alternative to removing them and getting them coated.
Old May 9, 2008 | 12:39 PM
Wavbyby's Avatar
Wavbyby
I have used POR-15 heat resistant paint "factory manifold gray" available from TIP tools for $18 on at least 5 sets of factory exhaust manifolds and they have held up great. One small can will do at least 3 sets. The first one I coated was about 6years ago and still looks great. The best result is after blasting. The brush strokes disapear after the first heat. The cheap dressing will not last.
Old May 9, 2008 | 01:38 PM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
CALYX
Works great !!
Old May 9, 2008 | 10:56 PM
vette8121's Avatar
vette8121
I've also used the POR 15 manifold grey with good results, one small can goes a long way! TM
Old May 13, 2008 | 06:51 PM
rajsid's Avatar
rajsid
Do you think this is the same as what's sold through Ecklers?
http://www.por15.com/prodinfo.asp?grp=FMG&dept=8
Will 8 oz be enough to paint a pair of BB manifolds?
Old May 14, 2008 | 01:43 AM
RIJVETTES's Avatar
RIJVETTES
I wanted a permanent fix. I had the manifolds sandblasted and coated inside and out with aluminum. Looks like clean, flat silver. No more flaking, rust or greasy residue. Check out your yellow pages for a local sandblasting and coating company and go see what they can do. Jim
Old May 14, 2008 | 06:39 AM
den(thevetteman)78's Avatar
den(thevetteman)78
I use it on my manifolds and got enough for a set of headers. Still have some left.
To Exhaust Manifold Paint
