New Battery Questions
Old May 12, 2008 | 09:44 AM
Mick42767's Avatar
Mick42767
Default New Battery Questions
Can anybody recommend a battery for my 72 SB? I only drive it on weekends and the battery is some POS that came with the car. I use a battery tender, but I was thinking of getting an Optima. Any suggestions?
Old May 12, 2008 | 09:53 AM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I like to use Delco products when I can......this one is still going strong after 7yrs.
Old May 12, 2008 | 10:08 AM
Roughrider's Avatar
Roughrider
An Optima is an excellent battery but not really necessary. In fact, last year Consumer Reports did a test of batteries (though the Optima was not included), and the results were surprising. I have always had high regard for Interstate batteries...they were not that highly rated. They determined their Best Buy battery was the Maxx battery sold by Wal Mart. It's the one in the yellow case.
NAPA's best battery was highly rated as well but was significantly more expensive than Wal Mart's.
Old May 12, 2008 | 10:46 AM
PhyscoVette's Avatar
PhyscoVette
I have had a red top optima now for almost 8 years!
Old May 12, 2008 | 11:36 AM
PETKAH's Avatar
PETKAH
You really don't need a Optima but you do need a good battery - I don't think brand makes any difference - about $80 - look at the specs - you need good cranking amps, and storage amps - look at various threads - do a search - I drive my sb on weekends with no problems, no tender.
Old May 12, 2008 | 11:38 AM
Lon Wayne's Avatar
Lon Wayne
Default Vader Vette
I run Goodyear tires and Die Hard Batteries. store it for the winter no charger no start in the middle of the season starts up three yrs in A row so far .I put in A new one every 4 years. but have not re-placed me current one for 5 yrs now. I wonder how the die hard stacks up in quality????
Old May 12, 2008 | 11:49 AM
PETKAH's Avatar
PETKAH
To be more specific - in my '75 I have an Interstate battery with 650CCA and 850CA - that means CCA =cold cranking amps CA =cranking amps - and I've had it for 6+ years with no tender or jumps at all.
If it takes a while for the car to start/turn over you are using juice and if you don't have enough in storage the battery will need recharging. Then make sure the alternator is working propertly, and get a tune-up as your car will start quicker.
Old May 12, 2008 | 07:12 PM
dannyman's Avatar
dannyman
Your battery is only as good as your electrical system. If you have electrical problems a new battery will not correct them. If you use a battery tender and disconnect from the vehicle during winter storage, then it probably doesn't matter what manufacture you use. AC Delco has never let me down.
Old May 12, 2008 | 08:42 PM
OogieBoogie's Avatar
OogieBoogie
I have a five year old Duralast Gold in my vette (purchased by PO). The car sat for well over a year without being started. When I purchased it, I took the battery in for a full charge and it has been running strong every since.
Old May 13, 2008 | 06:59 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I like Optima reds, personally. Expensive, but they wear like iron.
Old May 14, 2008 | 08:48 AM
FB007's Avatar
FB007
There are only 3 battery manufacturers in the US. They are virtually identical. Buy the cheapest one.It just doesn't matter.
Old May 14, 2008 | 02:50 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
The three companies products may be very similar, but there is a big difference between a wet-cell and a gel-cell battery.
Old May 9, 2009 | 11:22 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
That's the problem I'm having now. Car sat for over a year, I was glad it started up though. Battery was about 3-4 years old and still had enough to crank her over.
However, once the electric fans are running the battery doesn't have enough umpf to start the engine with the fans running. I trickle charged the battery fully but still not much help when the fans are running.
Never tried an Optima, I like buying the $60-$100 batteries with the highest CC amps. Once I got six years out of one. I've heard a lot of both good & bad about the Optima's. Just don't like spending $200 on a battery.
Old May 9, 2009 | 12:51 PM
7T1vette's Avatar
7T1vette
If your battery is fully charged and still has problems starting when your electric fans are running, you have a defect in the electrical system somewhere....most likely a bad connection, degraded wiring, worn-out starter solenoid, or weak battery that 'appears' to be charged but doesn't supply adequate amperage. Check the main ground wire between starter mounting bracket and engine mount bracket.
Old May 9, 2009 | 12:57 PM
wer2xu's Avatar
wer2xu
Lead Acid battery work best and last longer when kept at a full charge...hence the battery tender.
Old May 9, 2009 | 01:00 PM
June Bug's Avatar
June Bug
I have a Optima red top it lasted a year now I have to keep a charger on the POS or it won't start after a day or two it's more likely a short plus it has a car alarm too so there is probably the battery drain there
How can you tell if a battery is a gel cell or wet and what is a Optima red top?
Old May 9, 2009 | 01:16 PM
anmracing's Avatar
anmracing
St. Jude Donor '09
We use Duracel. It starts once every couple of weeks with out a problem.
Optima is a unique design called Spiralcell Technology and provides many features not available in ordinary batteries, such as:
More plate surface, closer plate spacing and the ability to use high purity lead. RESULTING IN: Low internal resistance. This low resistance gives you more power in a smaller box, the ability to recharge much faster, and higher and cleaner voltage characteristics during discharge.
Immobilized plates (locked in place). RESULTING IN: Improved vibration resistance, no shedding of active paste material, no gradual loss of power and capacity as the battery ages. This gives you a battery that lasts longer and performs better throughout its life.
To New Battery Questions
