Steering Column - Should I...
Old May 12, 2008 | 08:51 PM
Emeightch's Avatar
Emeightch
Default Steering Column - Should I...
From what I can remember, it worked fine. Wondering if I should get it rebuilt as a preventative maintenance or do some cosmetic work? Any suggestions on paint, maintenance, etc...
Old May 12, 2008 | 09:04 PM
Gordonm's Avatar
Gordonm
If the bearings are good and the T&T is tight no need to take it apart. The lower bearing is usually the worst one. You do not need to take it apart to replace that bearing. Cosmetic can be done without to much trouble.
Old May 12, 2008 | 09:29 PM
Artsvette73's Avatar
Artsvette73
change out the lower bearing while you have it out. Just be carefull handeling the column while it is out. That 77 turn signal arm snaps off easy
Old May 12, 2008 | 10:49 PM
Scott Marzahl's Avatar
Scott Marzahl
There are a couple pics of the lower bearing change at the end of these pics for you.
http://blog.scottsvettetalk.com/2008...n-rebuild.aspx
Old May 12, 2008 | 11:49 PM
Jim Shea's Avatar
Jim Shea
From the shop manual, how to change the lower bearing.
Jim
Old May 13, 2008 | 06:22 PM
Emeightch's Avatar
Emeightch
OK, I did a little "light" disassembly. Is the plastic part supposed to be cracked and is that thin seal ring supposed to be split under the retainer cap? Also, is the bearing I should replace the one pressed onto the center shaft?
I feel a big can of worms coming on here. I'm wondering if I should hurry up and put it back together before I get in too deep (again).
By the way, there is some play between the shaft and bearing.
Old May 13, 2008 | 06:26 PM
Scott Marzahl
That metal ring is what is left of the bottom portion of your lower bearing, the top portion of the bearing (to the right) is what snaps into the plastic holder which should not be cracked.
So far you need a new lower bearing and bearing holder and more than likely a new "rag joint".
Old May 13, 2008 | 07:23 PM
Gordonm's Avatar
Gordonm
Too late. You should be able to just replace the bearing and the plastic retainer. Getting the bearing off the shaft was a problem. I had to cut mine off.
To Steering Column - Should I...
