Carb designed for zz4
Old May 12, 2008 | 09:21 PM
ZZ71S's Avatar
ZZ71S
Default Carb designed for zz4
Has anyone seen the Barry Grant carb that is designed for the zz4
I think the PN is 1282010 vc
Is this carb really designed for the zz4,or is it just a stock carb that they are trying to sale as a custom
What carbs are you guys running with your zz4s I have a Holley 770 street adv
Old May 12, 2008 | 10:48 PM
Green76's Avatar
Green76
ZZ71S,
I still use my original Quadrajet carb that came with my L-48, the only thing I did was rebuild it...
I also installed an electric choke.
Old May 13, 2008 | 07:13 AM
kyeakel's Avatar
kyeakel
I have an Edelbrock 1411 750cfm square bore. Not real happy with it, either.
Kipp
Old May 13, 2008 | 10:16 AM
MakoShark72's Avatar
MakoShark72
Holley Street Avenger 670. Havent fired it up yet, though!
Old May 13, 2008 | 06:23 PM
Binnie77's Avatar
Binnie77
I have the Speed Demon ZZ4 carb on my car. The part number was 1282010CZZ4 when I bought it. It is basically a right out of the box and fire up installation. No problems with it except I just recently removed the electric choke as it is useless.
Old May 13, 2008 | 09:40 PM
Jason Staley's Avatar
Jason Staley
Cruise-In III Veteran
Kipp
I tried an Edelbrock on my ZZ4 also and for some reason I had a terrible time with that carb. I've used Edelbrocks before with good success, but the ZZ4 just didn't like it. I ended up with a BG mech secondary ZZ4 carb. Took a bit of tuning due to my heads being ported and I have GM's hot cam in the engine now, but I'm pleased with the carb.
The only difference between the ZZ4 carb and other BG's is the tuning. They've adjusted some of the air bleads & orifices to tune their general purpose carb for the ZZ4 setup.
Old May 14, 2008 | 12:00 PM
gatorbcn's Avatar
gatorbcn
I have a Holley 830 with annular boosters, no electric choke. Started with a Holley 750DP - never dynoed, but the 830 made a real seat of the pants difference. It took a little carb tinkering to make it run right (jets, power valves, etc.) and I had to go to a MSD ignition system (pro billet distributor, 6AL box and blaster coil) to get enough "spark."
Old May 14, 2008 | 12:28 PM
TopGunn's Avatar
TopGunn
Running my original Q-Jet, rebuilt and modified slightly for performace.
Old May 17, 2008 | 12:14 AM
tnovot's Avatar
tnovot
I also have a Holley Avenger 670 with electric choke on my ZZ4. Works great.
Terry
To Carb designed for zz4
